Beep-media-player crashes:(
Dont know why byt my BMP crsahes
rt@Robert ~ $ beep-media-player The program 'beep-media-player' received an X Window System error. This probably reflects a bug in the program. The error was 'BadAccess (attempt to access private resource denied)'. (Details: serial 12 error_code 10 request_code 33 minor_code 0) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the --sync command line option to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.)
Dont know if I have did something wrong, else in fluxbox works good,
I thing that its worked with my config I tryed to do from plain config, but then realize to find some on net and edit it…
Here it is
### Environnement Settings
#### Set image path
ImagePath ${HOME}/.fvwm/images:+
SetEnv fvwm_image_path $[HOME]/
#### Set the wallpaper utility and wallpapers directory
SetEnv fvwm_root "feh --bg-scale "
SetEnv fvwm_wallpaper_dir $[HOME]/.fvwm/wallpapers/
#### Set the audio/mp3 directory
SetEnv fvwm_audio_path $[HOME]/hudba/
SetEnv fvwm_audio_exec "beep-media-player -e"
#### Set the video directory
SetEnv fvwm_video_path $[HOME]/video/
SetEnv fvwm_video_exec "mplayer"
#### Set scripts path
SetEnv fvwm_script_path $[FVWM_USERDIR]/scripts/
#### Set playlits path
SetEnv fvwm_playlist_path $[FVWM_USERDIR]/playlist
#### Set default applications
SetEnv browser firefox
SetEnv music_player beep-media-player
### Starting and Exiting
#### Splashscreen and RootTerminal only at Init
AddtoFunc InitFunction
+ I Module FvwmBanner
+ I Exec exec conky
+ I Exec exec feh --bg-scale /mnt/docs/Dokumenty/Obrazky/nekronos_1600x1200.jpg
+ I Exec exec licq -p icqnd
#### Start Function
#### Launch needed Fvwm Modules
AddToFunc StartFunction
+ I Test (Restart) All (Iconic) Test (f $[FVWM_USERDIR]/icon.tmp.$[w.id].png) WindowStyle IconOverride, Icon $[FVWM_USERDIR]/icon.tmp.$[w.id].png
+ I Module FvwmCommands
+ I Module FvwmPager
#+ I Module FvwmButtons -g 70x570-0+170 FvwmDock
+ I Module FvwmAnimate
#### Exit Function
AddToFunc ExitFunction
+ I Test (!ToRestart) Exec exec rm -f $[HOME]/.fvwm/icon.tmp.*
### General Settings
#### Set the Desktop Size
DeskTopSize 2x2
IgnoreModifiers L25
SnapAttraction 5
EdgeScroll 0 0
EdgeResistance 1000 20
EdgeThickness 1
ClickTime 150
MoveThreshold 3
OpaqueMoveSize unlimited
HideGeometryWindow Always
BugOpts FlickeringMoveWorkaround Off
SnapGrid 1 1
ColormapFocus FollowsFocus
Style * Colorset 3, HilightColorset 4
Style * Font "Shadow=1 1 SE:xft:Concielian:pixelsize=12"
Style * SmartPlacement, WindowShadeSteps 0, ResizeOpaque
Style * DecorateTransient, WindowShadeLazy
Style * IconBox 15 15 -1 1, MouseFocusClickRaises
Style * NoIcon, NoIconTitle
Style * !Borders, NoHandles
### Colorsets
#### Menu Colorset
Colorset 0 fg #000000, fgsh #bbbbbb, bg #ffffff, sh #ffffff, hi #ffffff, Translucent #ffffff 70
Colorset 1 fg #ffffff, fgsh #000000, bg #101F36, sh #101F36, hi #101F36
### General Colorset
Colorset 3 fg #777777, bg #ffffff, fgsh #bbbbbb, RootTransparent, Tint #283e5e 70, IconAlpha 60
Colorset 4 fg #000000, bg #ffffff, fgsh #bbbbbb, RootTransparent, Tint #101f36 70, IconAlpha 100
Colorset 5 fg #ffffff, bg #000000
Colorset 6 fg #ffffff, bg #000000, RootTransparent
#### Dock Colorset
Colorset 30 fg #ffffff, bg #ffffff, hi #dde5ec, sh #a6bbce, RootTransparent , Tint #101F36 65
### CursorStyle
#### Change style to left_ptr and fleur (missing cursors in my cursors theme)
CursorStyle root left_ptr
CursorStyle default left_ptr
CursorStyle position left_ptr
CursorStyle sys left_ptr
CursorStyle menu left_ptr
CursorStyle title left_ptr
CursorStyle resize fleur
CursorStyle stroke cross
CursorStyle select draped_box
### Titlebar Decoration
DestroyFunc FuncFvwmDecorBackground
AddToFunc   FuncFvwmDecorBackground
+ I TitleStyle AllActive   TiledPixmap decoration/siro/wtitle.xpm
+ I TitleStyle AllInactive TiledPixmap decoration/siro/wtitle.xpm
+ I ButtonStyle All Simple -- UseTitleStyle
+ I FuncFvwmDecorBackground
AddButtonStyle 1 \
    ActiveUp   (Pixmap decoration/siro/stick.xpm -- flat) \
    ActiveDown (Pixmap decoration/siro/stick.xpm -- flat) \
    Inactive   (Pixmap decoration/siro/stick.xpm -- flat)
AddButtonStyle 6 \
    ActiveUp   (Pixmap decoration/siro/icon.xpm -- flat) \
    ActiveDown (Pixmap decoration/siro/icon.xpm -- flat) \
    Inactive   (Pixmap decoration/siro/icon.xpm -- flat)
AddButtonStyle 4 \
    ActiveUp   (Pixmap decoration/siro/max.xpm -- flat) \
    ActiveDown (Pixmap decoration/siro/max.xpm -- flat) \
    Inactive   (Pixmap decoration/siro/max.xpm -- flat)
AddButtonStyle 2 \
    ActiveUp   (Pixmap decoration/siro/close.xpm -- flat) \
    ActiveDown (Pixmap decoration/siro/close.xpm -- flat) \
    Inactive   (Pixmap decoration/siro/close.xpm -- flat)
Style "*" Button 1, Button 2, Button 4, Button 6, GrabFocusOff
Style "*" FvwmButtons
AddToFunc   FuncFvwmReloadDecor
+ I BorderStyle Simple -- HiddenHandles NoInset
+ I TitleStyle  -- Flat
+ I ButtonStyle All -- Flat
FuncFvwmReloadDecor
TitleStyle Height 20
### Styles
#### Fvwm Modules Styles
Style FvwmPager    NoTitle,  Sticky, WindowListSkip, CirculateSkipIcon, CirculateSkip
Style FvwmPager    StaysOnBottom, NoHandles, BorderWidth 0
Style FvwmDock     Sticky, NoTitle, NoHandles, Borderwidth 0
Style FvwmDock     WindowListSkip, StaysOnBottom
#### Applications Styles
#Style GameConsole NoTitle, Sticky, WindowListSkip, CirculateSkipIcon, CirculateSkip
#Style GameConsole StaysOnTop, NoHandles, BorderWidth 0, WindowShadeSteps 150
Style firefox EWMHMiniIconOverride, MiniIcon icons/globes/internet.png
Style thunderbird EWMHMiniIconOverride, MiniIcon icons/globes/mail.png
Style leafpad  EWMHMiniIconOverride, MiniIcon icons/globes/edit.png
Style aterm  EWMHMiniIconOverride, BorderWidth 0, MiniIcon icons/globes/console.png
Style gimp EWMHMiniIconOverride, MiniIcon icons/globes/gimp.png
Style gFTP EWMHMiniIconOverride, MiniIcon icons/globes/ftp.png
Style MPlayer NoTitle, Sticky, WindowListSkip
Style beep-media-player MiniIcon icons/globes/audio.png
Style Untitled  NoTitle
Style licq MiniIcon icons/globes/chat.png
#### Override others icons
Style * EwmhMiniIconOverride
### Mouse Bindings
#### Root Menus
Mouse 1     R       A   -
Mouse 3     R       A   Menu MenuFvwmRoot
Mouse 2     R       A   WindowList NoCurrentDeskTitle
#### Titlebar Buttons
Mouse 1     1       A   Menu MenuFvwmWindowOps
Mouse 3     1       A   Menu MenuFvwmwindowOps
Mouse 1     6       A   Thumbnail
Mouse 1     4       A   Maximize
Mouse 1     2       A   Close
#### Window, Frame, Side, Others
Mouse 1     FS      A   ResizeFunc
Mouse 2     W       C   ResizeFunc
Mouse 1     W       M   MoveFunc
Mouse 3     W       M   ResizeFunc
Mouse 3     TSIF    A   RaiseLower
Mouse 3     T       A   Menu MenuFvwmWindowOps
AddToFunc ResizeFunc "M" Resize
AddToFunc MoveFunc   "M" Move
#### Icons Binding
Mouse 1     I       A   Iconify
Mouse 2     I       A   Move
#### Wheel Toggle Shade
Mouse 4     T       N   WindowShade True
Mouse 5     T       N   WindowShade False
Mouse 4     TW      M   WindowShade True
Mouse 5     TW      M   WindowShade False
#### Mouse Gesture Binding
Mouse 1     R       A   StrokeFunc
Mouse 1     W       CM  StrokeFunc
### Keyboard Bindings
Key Tab A M Windowlist Root c c NoCurrentDeskTitle
#### Windows Key Root Menu
Key Super_L  A  A   Menu MenuFvwmRoot
Key Super_R  A  A   Menu MenuFvwmRoot
#### Traditional Bindings
Key F4 A        M   Pick Close
Key X  A        M   Pick Destroy
#### Fvwm Special Bindings
Key F3 A        M   Module FvwmConsole -terminal xterm
Key I  A        M   Pick Module FvwmIdent
Key R  A        CM  Restart
Key F4 A        CM  Quit
#### Applications Bindings
Key F1 A        M   Exec exec gnome-terminal
#### Multimedia Keys Bindings
Key XF86AudioMute        A A Exec exec aumix -vn
Key XF86AudioRaiseVolume A A Exec exec aumix -v+5
Key XF86AudioLowerVolume A A Exec exec aumix -v-5
Key XF86AudioMedia       A A Exec exec xmms
Key XF86Mail             A A Exec exec thunderbird
#### Pager Bindings
Key Right A CM GoToPage +1p  0p
Key Left  A CM GoToPage -1p  0p
Key Up    A CM GoToPage  0p -1p
Key Down  A CM GoToPage  0p +1p
### Menu Settings
MenuStyle * Hilight3DOff, PopupOffset +0 100, PopupDelay 200
MenuStyle * Font "Shadow=1 1 SE:xft:Concielian:pixelsize=12"
MenuStyle * MenuColorset 0, HilightBack, ActiveColorset 1
MenuStyle * BorderWidth 0, TitleUnderlines0, SeparatorsLong, Animation, TrianglesSolid
MenuStyle * ItemFormat "%.2|%.5i%.5l%.5i%2.3>%2|"
MenuStyle * AutomaticHotKeys
### Menu
DestroyMenu MenuFvwmRoot
AddToMenu MenuFvwmRoot
+   "&File manager"%icons/globes/folder.png%	Exec exec emelfm2
+   "&Terminal"%icons/globes/console.png%   	Exec exec aterm -tr -trsb -sb -bw 0 -pmo -rv -sh 60 -sl 2000
+   ""                                      Nop
+   "Internet"%icons/globes/internet.png%      	Popup MenuInternet
+   "Multimedia"%icons/globes/multimedia.png%  	Popup MenuMultimedia
+   "Office"%icons/globes/edit.png%            	Popup MenuOffice
+   "Utility"%icons/globes/utils.png%          	Popup MenuUtilities
+   "Preferneces"%icons/globes/prefs.png%      	Popup MenuFvwmConfig
+   ""                                      Nop
+   "Quit"%icons/globes/exit.png%              	Popup MenuQuit-Verify
	DestroyMenu MenuOffice
	AddToMenu MenuOffice
	+   "OOo &Writer"%icons/globes/edit.png%       	Exec exec xoowriter
	+   "OOo &Calc"%icons/globes/calc.png%         	Exec exec xoocalc
	+   "Leafpad"%icons/globes/edit.png%           	Exec exec leafpad
	+   ""                                      Nop
	+   "&Qcad"%icons/globes/utils.png% 		Exec exec qcad
	+   ""                                      Nop
	+   "&Ximian OOo"%icons/globes/edit.png%       	Exec exec xooffice
	DestroyMenu MenuInternet
	AddToMenu MenuInternet
	+   "&Firefox"%icons/globes/internet.png%   		Exec exec firefox
	+   "&Thunderbird"%icons/globes/mail.png%   		Exec exec thunderbird
	+   "Dillo"%icons/globes/internet2.png%   		Exec exec dillo
	+   ""                                      Nop
	+   "Gftp"%icons/globes/ftp.png%                  	Exec exec gftp
	+   "Wget"%icons/globes/ftp.png%                  	Exec exec gwget
	+   "Licq"%icons/globes/chat.png%                  	Exec exec licq -p icqnd
	+   "P2P"%icons/globes/internet2.png%                  	Popup MenuP2P
	+   ""                                      Nop
	+   "Sites"%icons/globes/internet2.png%             	Popup MenuFvwmWeb
	+   "News"%icons/globes/internet2.png%              	Popup MenuFvwmHeadlines
		DestroyMenu MenuP2P
		AddToMenu MenuP2P
		+  "DCpp"			Exec exec /home/robert/Progs/dcpp/./dcpp
		+  "GiftToxic"			Exec exec giFToxic
		DestroyMenu MenuFvwmWeb
		AddToMenu MenuFvwmWeb
		+  "Info"                      	Popup MenuFvwmInformatique
		+  "Forums"			Popup MenuFvwmForums
			DestroyMenu MenuFvwmInformatique
			AddToMenu MenuFvwmInformatique
			+  "Gentoo"                                 Exec exec $[browser] http://wwww.gentoo.org
			DestroyMenu MenuFvwmForums
			AddToMenu MenuFvwmForums
			+  "Clubic"                                 Exec exec $[browser] http://forum.clubic.com
			+  "PcInpact"                               Exec exec $[browser] http://www.pcinpact.com/forum/
			+  "Gentoo"                                 Exec exec $[browser] http://forums.gentoo.org
	DestroyMenu MenuMultimedia
	AddToMenu MenuMultimedia
	+ MissingSubmenuFunction FuncFvwmMenuDirectory
	+   "&BMP"%icons/globes/multimedia2.png%       	Exec exec beep-media-player
	+   "Aumix"					Exec exec aumix
	+   "Xmms"%icons/globes/multimedia2.png%      	Exec exec xmms
	+   ""					Nop
	+   "The &Gimp"%icons/globes/gimp.png%        	Exec exec gimp
	+   "Picture view"%icons/globes/gimp.png%	Exec exec gqview
	+   "Palba"%icons/globes/k3b.png%              	Exec exec
	+   "Mplayer"%icons/globes/multimedia.png%     	Exec exec gmplayer
	+   ""                                 	Nop
	+   "&Video"%icons/globes/folder.png%  		Popup $[fvwm_video_path]
	+   "&Music"%icons/globes/folder.png% 		Popup $[fvwm_audio_path]
		DestroyMenu MenuFvwmRadio
		AddToMenu MenuFvwmRadio
		+   "Digitally Imported"                    Popup MenuFvwmRadioDI
			DestroyMenu MenuFvwmRadioDI
			AddToMenu MenuFvwmRadioDI
			+   "Trance"                                Exec exec $[music_player] $[fvwm_playlist_path]/trance96k.pls
			+   "Hard Trance"                           Exec exec $[music_player] $[fvwm_playlist_path]/hardtrance96k.pls
			+   "Vocal Trance"                          Exec exec $[music_player] $[fvwm_playlist_path]/vocaltrance96k.pls
			+   "Euro Dance"                            Exec exec $[music_player] $[fvwm_playlist_path]/eurodance96k.pls
			+   "Goa-Psy Trance"                        Exec exec $[music_player] $[fvwm_playlist_path]/goapsy96k.pls
			+   "Deep House"                            Exec exec $[music_player] $[fvwm_playlist_path]/deephouse96k.pls
			+   "Hard House"                            Exec exec $[music_player] $[fvwm_playlist_path]/hardhouse96k.pls
			+   "Hard Core"                             Exec exec $[music_player] $[fvwm_playlist_path]/hardcore96k.pls
			+   "Classic Techno Trance"                 Exec exec $[music_player] $[fvwm_playlist_path]/classictechno96k.pls
			+   "Chillout"                              Exec exec $[music_player] $[fvwm_playlist_path]/chillout96k.pls
			+   "DJ Mixes"                              Exec exec $[music_player] $[fvwm_playlist_path]/djmixes96k.pls
	DestroyMenu MenuUtilities
	AddToMenu MenuUtilities
	+   "TuxCMD"%icons/globes/folder.png%		Exec exec /home/robert/Progs/tuxcmd/./tuxcmd
	+   "Sys-monitor"%icons/globes/display.png%	Exec exec gps
	+   ""					Nop
	+   "Root"%icons/globes/utils.png%		Popup MenuRoot
	+   "AthCool"%icons/globes/utils.png%		Popup MenuAthcool
	+   "Xterm"%icons/globes/console.png%		Exec exec xterm
	+   ""                                 	Nop
	+   "Screenshot"%icons/globes/display.png%  	Exec exec $[fvwm_script_path]/screenshot.sh
		DestroyMenu MenuRoot
		AddToMenu MenuRoot
		+ "Xnest"%icons/globes/display.png% 	Exec exec gdmflexiserver -n
		+ "Porthole"%icons/globes/utils.png%	Exec exec porthole
		DestroyMenu MenuAthcool
		AddToMenu MenuAthcool
		+ "Athcool ON"%icons/globes/utils.png%	Exec exec sudo /usr/sbin/athcool on
		+ "Athcool OFF"%icons/globes/utils.png%	Exec exec sudo /usr/sbin/athcool off
	DestroyMenu MenuQuit-Verify
	AddToMenu MenuQuit-Verify
	+   "Restart"%icons/globes/reload.png%         	Restart
	+   "Shutdown"%icons/globes/exit.png% 		Exec exec sudo shutdown -h now
	+   "Reboot"%icons/globes/reload.png%		Exec exec sudo shutdown -r now
	+   "Logout"%icons/globes/exit.png%        	Quit
	DestroyMenu MenuFvwmConfig
	AddToMenu MenuFvwmConfig
	+ MissingSubmenuFunction WallpaperBrowser
	+   "Wallpapers"%icons/globes/prefs.png%    	Popup $[fvwm_wallpaper_dir]
	+   "GTK-Theme"%icons/globes/edit.png% 		Exec exec gtk-chtheme
	+   "Xscreensaver"%icons/globes/edit.png%	Exec exec xscreensaver-demo
	+   ""                                      Nop
	+   "FvwmConsole"%icons/globes/display.png% 	Module FvwmConsole -terminal xterm
	+   "Edit fvwm2rc"%icons/globes/edit.png%      	Exec exec leafpad ~/.fvwm/.fvwm2rc
	+   "Refresh"%icons/globes/reload.png%         	Refresh
	+   "Kill"%icons/globes/exit.png%             	Pick Destroy
#### Window menu
DestroyMenu MenuFvwmWindowOps
AddToMenu MenuFvwmWindowOps
+   "Resizer"                        Pick Resize
+   "Shade"                                 Pick WindowShade Toggle
+   "S&tick"                                Pick Stick
+   "Ra&fresh"                           Pick RefreshWindow
+   ""                                      Nop
+   "Identification"                        Pick Module FvwmIdent
+   ""                                      Nop
+   "Send to"                          Popup MenuFvwmSendTo
+   ""                                      Nop
+   "Close"                                Close
+   "Kill"                                  Destroy
	DestroyMenu MenuFvwmSendTo
	AddToMenu MenuFvwmSendTo
	+   "Page &1" MoveToPage 0 0
	+   "Page &2" MoveToPage 1 0
	+   "Page &3" MoveToPage 0 1
	+   "Page &4" MoveToPage 1 1
### Thumbnails
SetEnv fvwm_icon_size 128
DestroyFunc Thumbnail
AddToFunc Thumbnail
+ I Raise
+ I SetEnv Icon-$[w.id] $[w.iconfile]
+ I ThisWindow (!Shaded Iconifiable !Iconic) PipeRead \
    "xwd -silent -id $[w.id] | convert -scale $[fvwm_icon_size] -frame 1x1 \
    -mattecolor black -quality 0 xwd:- png:$[FVWM_USERDIR]/icon.tmp.$[w.id].png \
    && echo WindowStyle IconOverride, Icon $[FVWM_USERDIR]/icon.tmp.$[w.id].png \
    || echo Nop"
+ I TestRc (Match) Test (f $[HOME]/icons/$[w.miniiconfile]) PipeRead "composite -geometry +2+4 \
    $[HOME]/icons/$[w.miniiconfile] $[FVWM_USERDIR]/icon.tmp.$[w.id].png \
    $[FVWM_USERDIR]/icon.tmp.$[w.id].png && echo Nop \
    || echo Beep"
+ I Iconify
DestroyFunc DeThumbnail
AddToFunc DeThumbnail
+ I PipeRead "echo WindowStyle Icon \\$\\[Icon-$[w.id]\\]"
+ I UnsetEnv Icon-$[w.id]
+ I Exec exec rm -f $[FVWM_USERDIR]/icon.tmp.$[w.id].png
#*FvwmEvent: deiconify DeThumbnail
#### Comment out these lines if you don't like Icons to have Titles.
#Colorset 12 fg white, bg black, fgsh black, RootTransparent
#Style * IconTitle, IconTitleColorset 12, HilightIconTitleColorset 12, IconTitleRelief 0
#Style * IconFont "Shadow=1 1 SE:xft:Concielian:pixelsize=12", IndexedIconName, IconBackgroundPadding 0
#Style * IconBackgroundRelief 0, IconBackGroundColorset 12
### Pager
*FvwmPager: Geometry 200x114-0-0
*FvwmPager: MiniIcons
*FvwmPager: Colorset * 60
*FvwmPager: HilightColorset * 61
*FvwmPager: WindowColorsets 63 62
*FvwmPager: BalloonColorset * 63
*FvwmPager: Font none
*FvwmPager: SmallFont none
*FvwmPager: Balloons All
*FvwmPager: BalloonFont "Shadow=1 1 SE:xft:Concielian:pixelsize=12"
*FvwmPager: BalloonYOffset +2
*FvwmPager: BalloonBorderWidth 1
*FvwmPager: UseSkipList
*FvwmPager: MoveThreshold 0
*FvwmPager: SolidSeparators
*FvwmPager: WindowBorderWidth 1
#### Pager Colorset
Colorset 60 fg white, bg #ffffff, RootTransparent
Colorset 61 fg white, bg #ffffff, Noshape, RootTransparent, Tint #ffffff 50
Colorset 62 fg white, bg #ffffff, RootTransparent, Tint #101F36 90
Colorset 63 fg white, bg #ffffff, Noshape, RootTransparent, Tint #101F36 60
### Dock
DestroyModuleConfig FvwmDock: *
*FvwmDock: Rows 10
*FvwmDock: Columns 1
*FvwmDock: Frame 0
*FvwmDock: Colorset 30
*FvwmDock: (1x1, Icon dock/globes/home.png, ActionOnPress, Action(Mouse 1) `DockLaunch "nautilus --no-desktop" nautilus $left $top`, Action(Mouse 3) `Next (nautilus) Popup MenuFvwmWindowOps Rectangle +$left+$top -100m 0`, HoverIcon dock/globes/home_hover.png)
*FvwmDock: (1x1, Icon dock/globes/firefox.png, ActionOnPress, Action(Mouse 1) `DockLaunch firefox Firefox-bin $left $top`, Action(Mouse 3) `Next (Firefox-bin) Popup MenuFvwmWindowOps Rectangle +$left+$top -100m 0`, HoverIcon dock/globes/firefox_hover.png)
*FvwmDock: (1x1, Icon dock/globes/xmms.png, ActionOnPress, Action(Mouse 1) `DockLaunch xmms $left $top`, Action(Mouse 3) `Menu MenuMultimedia Rectangle +$left+$top -100m 0`, HoverIcon dock/globes/xmms_hover.png)
*FvwmDock: (1x1, Icon dock/globes/mail.png, ActionOnPress, Action(Mouse 1) `DockLaunch thunderbird Thunderbird-bin $left $top`, Action(Mouse 3) `Next (Thunderbird-bin) Popup MenuFvwmWindowOps Rectangle +$left+$top -100m 0`, HoverIcon dock/globes/mail_hover.png)
*FvwmDock: (1x1, Icon dock/globes/gimp.png, ActionOnPress, Action(Mouse 1) `DockLaunch gimp-2.0 gimp-2.0 $left $top`, Action(Mouse 3) `Next (gimp-2.0) Popup MenuFvwmWindowOps Rectangle +$left+$top -100m 0`, HoverIcon dock/globes/gimp_hover.png)
*FvwmDock: (1x1, Icon dock/globes/edit.png, ActionOnPress, Action(Mouse 1) `DockLaunch gvim gvim $left $top`, Action(Mouse 3) `Next (gvim) Popup MenuFvwmWindowOps Rectangle +$left+$top -100m 0`, HoverIcon dock/globes/edit_hover.png)
#*FvwmDock: (1x1, Icon dock/bluefish.png, ActionOnPress, Action(Mouse 1) `DockLaunch bluefish bluefish $left $top`, Action(Mouse 3) `Next (bluefish) Popup MenuFvwmWindowOps Rectangle +$left+$top -100m `)
#*FvwmDock: (1x1, Icon dock/ooo.png, ActionOnPress, Action(Mouse 1) `DockLaunch xooffice xooffice $left $top`, Action(Mouse 3) `Next (xooffice) Popup MenuFvwmWindowOps Rectangle +$left+$top -100m 0`)
*FvwmDock: (1x1, Icon dock/globes/console.png, ActionOnPress, Action(Mouse 1) `Exec gnome-terminal`, HoverIcon dock/globes/console_hover.png)
*FvwmDock: (1x1, Icon dock/globes/system.png, ActionOnPress, Action(Mouse 1) `Exec gvim -geom 115x46 ~/.fvwm/.fvwm2rc`, HoverIcon dock/globes/system_hover.png)
DestroyFunc DockLaunch
AddToFunc DockLaunch
+ C Any ($1) Next ($1) WindowListFunc
+ C TestRc (NoMatch) Exec $0
+ H Any ($1) WindowList ($1) Rectangle +$2+$3 0 -100m CurrentAtEnd UseListSkip SortByClass NoCurrentDeskTitle
+ D Exec $0
### Animation
DestroyModuleConfig FvwmAnimate: *
*FvwmAnimate: Color white
*FvwmAnimate: Effect frame
*FvwmAnimate: Delay 3
*FvwmAnimate: Iterations 50
*FvwmAnimate: Width 1
### Directory Browsing
#### Browse Audio/Video Directory
DestroyFunc FuncFvwmMenuDirectory
AddToFunc FuncFvwmMenuDirectory
+ I PipeRead 'case "$0" in \
        "$[fvwm_video_path]"*) myexec="$[fvwm_video_exec]" mypng=icons/globes/video.png;; \
        "$[fvwm_audio_path]"*) myexec="$[fvwm_audio_exec]" mypng=icons/globes/audio.png;; \
    esac; \
    fvwm-menu-directory --icon-title icons/globes/folder.png --icon-file ${mypng:-icons/globes/folder.png} \
    --icon-dir icons/globes/folder.png --dir "$0" --exec-t="^${myexec:-gvim} *" \
    --exec-file "^${myexec:-gvim}"'
#### Browse Wallpapers Directory
DestroyFunc WallpaperBrowser
AddToFunc WallpaperBrowser
+ I PipeRead 'test ! -d "$0/.thumbs" && mkdir "$0/.thumbs"; \
    for i in "$0/"*; do \
        test -f "$0/.thumbs/${i##*/}" \
            -a "${i}" -ot "$0/.thumbs/${i##*/}" || { \
                convert -quality 0 -scale 64 "${i}" "png:$0/.thumbs/${i##*/}" 2>/dev/null \
                    || continue; \
    done; \
    fvwm-menu-directory --icon-title icons/globes/folder.png --icon-file __PIXMAP__ \
    --icon-dir icons/globes/folder.png --dir $0 --exec-file "^fbsetbg -f" \
    --exec-t="^eog *" | sed -e "s#FuncFvwmMenuDirectory#WallpaperBrowser#g" \
    -e "s#__PIXMAP__\\(.*\\)\\"\\(.*/\\)\\(.*\\)\\"#\\2.thumbs/\\3\\1\\2\\3#g"'
### Headlines
DestroyFunc FuncFvwmMenuHeadlines
AddToFunc   FuncFvwmMenuHeadlines
+ I PipeRead `fvwm-menu-headlines --frontpage --site $0 --exec="firefox '%u'"
DestroyMenu MenuFvwmHeadlines
AddToMenu   MenuFvwmHeadlines "News" Title
+ MissingSubmenuFunction FuncFvwmMenuHeadlines
+ "FreshMeat"  Popup freshmeat
+ "Slashdot"   Popup slashdot
+ "LinuxFr"    Popup linuxfr
+ "Reset"  FuncFvwmResetHeadlines
DestroyFunc FuncFvwmResetHeadlines
AddToFunc   FuncFvwmResetHeadlines
+ I DestroyMenu freshmeat
+ I DestroyMenu slashdot
+ I DestroyMenu linuxfr
### FvwmIdent
DestroyModuleConfig FvwmIdent: *
*FvwmIdent: Back #101F36
*FvwmIdent: Fore #ffffff
*FvwmIdent: Font "xft:sans:bold:pixelsize=10:minspace=True"
### FvwmBanner (Splash Screen)
*FvwmBanner: NoDecor
*FvwmBanner: Pixmap splash/gentoo.png
*FvwmBanner: Timeout 3
### Mouse Gestures
Stroke N159   0 W CM Pick Close
Stroke N951   0 W CM Thumbnail
Stroke N258   0 W CM Maximize
#### Pager Gestures
Stroke N456 0 R N    GotoPage +1p  0p
Stroke N654 0 R N    GotoPage -1p  0p
Stroke N258 0 R N    GotoPage  0p -1p
Stroke N852 0 R N    GotoPage  0p +1p
Stroke N753 0 R N    GotoPage +1p +1p
Stroke N357 0 R N    GotoPage -1p -1p
Stroke N159 0 R N    GotoPage +1p -1p
Stroke N951 0 R N    GotoPage -1  +1p
#### Launch Applications
Stroke N98741 0 R N Exec exec firefox
Stroke N12369 0 R N Exec exec thunderbird
Stroke N789852 0 R N Exec exec gnome-terminal
Stroke N9874123 0 R N Exec exec gvim -geom 115x46 ~/.fvwm/.fvwm2rc
#### Restart
Stroke N789632147 0 R N Restart
I doubt this to be FVWM’s fault. I’d be more interested in obtaining the backtrace left from the core file.
So I have found the problem at last:)
It was because I use Itouch plugin in BMP, and the config have defined some multimedia keys, and it cant be together, (I have found it out because I emerge XMMS and try that and worked and than witch iTouch didnt…),
I have erased these lines and everything is ok,(This lines doesnt work for me, coz I dont use gnome-settings)
[code]
Key XF86Mail A A Exec exec thunderbird [/code]
