i found a makefile on this forum for the thumbnailings so thanks to the author
msantinho for the weather popup
and the fvwm community .
[color=red]28-10-2005[/color] : done !
theme switch : see Here(the last one is another theme !)
i will release the new tarball soon , i 've have to do some changes.
[color=red]12-11-2005[/color]
ok here it is :
sometimes, when you change of themes the terminal stay in the middle of he screen, you need to “CTRL + ESC” for masking it.
if you switch of themes with some windows opened , maybe they will loose their styles so u’ll need to restart.
and yeah it is still a little buggy .
[color=red]wed 23 nov[/color]
sorry , my account is suspended , i need to find a way to post my config.
freshmeat seems ok but it will available in one week so i’m looking for a solution.
cheers
Now thats a nice config !! Too bad it has rounded corners , though it seems pretty nice, is it fast ??
with so many pixmaps i bet its kind a slow isnt it ??
thanks to all
well , i dont really think it is slow but sometimes thumbnailings takes times to respond.
of course i will release it but i want to put in the config all the https of many people i was talking about in my top post.(included station linux sorry lucky )
the config is not dynamic and i do not plan to do it so it work well in 1024x768.
so for those who are interested i will release it tommorrow.
well , sorry but there is an unbeliveable mess in my config, i had to finish
to clean it before post it.
this is the latest shot , think it is ok , pfffiou.
EDIT : see the first post since i have updated the theme.
Some GUI programs refuse to run as root, and well should they, you should never sun X as root, or even log in as root to start with…there’s su and sudo and they have a reason for existing…
