DestroyFunc a
AddToFunc a
- I Schedule Periodic 1500 1003 b
DestroyFunc b
AddToFunc b
- I Deschedule 1003
DestroyFunc c
AddToFunc c
- I Deschedule 1003
When call function a, function b do not stop before function c is called.
DestroyFunc a
AddToFunc a
DestroyFunc b
AddToFunc b
DestroyFunc c
AddToFunc c
I have solve this problem with a little trick by using the FvwmCommands.
change the function b to:
DestroyFunc b
AddToFunc b
Overkill.
A simple additonal Schedule will do it:
Schedule 1 Deschedule foo
And yes, what you’re seeing is known about Schedule – has been for a long time now. There’s not a lot you can do about it.
