Wise fellows,
I’m reinventing the wheel again as there are thousands of calendars out there prettier than this one. Anyway I’d appreciate your comments, suggestions, improvements on this script.
I launch it from 2 buttons (‘date’ and ‘hour’ near the ‘power’ button) wich you can see here .
To run this calendar you need Perl and Calendar::Simple module (from CPAN).
########## SCRIPTS ######
calendario.pl
Calendar_popup
VoiDeR
3 September 2005 15:58
2
Wow this is really cool. I have been trying to write something like this for a week now but i could never get everything lined up right. Thanks this is great.
VoiDeR
To line up the days I had to use a fixed-width font: Monospace (and some tricks on Perl too )
I forgot to mention but I think it is easy to translate months and weekdays names: just edit the Perl file.
VoiDeR
3 September 2005 17:29
4
Already modified they day and months. I had to dig through the perl file cause i just had to figure out how you got it all to line up and stumbled apon that.
VoiDeR
What perl modules do i have to emerge ???
Mnto bom trabalho man, e bom ver ppl tuga por aki !!!
VoiDeR
8 September 2005 03:49
6
I dont think its in portage but heres a link to the source.
http://search.cpan.org/dist/HTML-Calendar-Simple/Simple.pm
Johan
8 September 2005 12:16
7
thanks voider, where do I put it?
or do I need to compile it somhow? I’m not familiar with perl
Johan
VoiDeR
8 September 2005 14:00
8
http://search.cpan.org/dist/Calendar-Simple/ Heres a link to the one i used. There are instructions in the tarball but pretty much all you have to do is
perl Makefile.PL
make
make test
make install
Johan
8 September 2005 15:06
9
thanks, that worked. At first, I only had Simple.pm…
Johan
japio
15 September 2005 13:59
11
here’s an english version of calendario.pl
#!/usr/bin/perl -Tw
# FILE: calendario.pl
# USAGE: ./calendario.pl
# DESCRIPTION: A small calendar for Fvwm
# AUTHOR: Miguel Santinho (), <msantinho@simplicidade.com>
# COMPANY: Simplicidade.com
# VERSION: 1.0
# CREATED: 03-09-2005 15:37:08 WEST
# REVISION: ---
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
use strict;
use Calendar::Simple;
my $months = {
1 => 'January',
2 => 'February',
3 => 'March',
4 => 'April',
5 => 'May',
6 => 'June',
7 => 'July',
8 => 'Agust',
9 => 'September',
10 => 'October',
11 => 'November',
12 => 'December',
my $mon = ((localtime)[4] + 1);
my $yr = ((localtime)[5] + 1900);
my @month = calendar($mon, $yr, 1);
# TITULO
print $months->{$mon}, " ", $yr, "\n";
# DIAS SEMANA
print "MON TUE WEN THU FRI SAT SUN\n";
foreach my $line (@month) {
foreach my $dia (@$line) {
my $dia_out = $dia;
# MARCAR DIA ACTUAL
$dia_out = "*" . $dia if $dia
$dia == (localtime)[3]
$mon == ((localtime)[4] + 1);
if ( $dia_out ) {
if ( length $dia_out == 1 )
print " " . $dia_out . " ";
} elsif ( length $dia_out == 2 )
} elsif ( length $dia_out == 3 )
print $dia_out . " ";
} else {
print " ";
print "\n";
