Hey guys,
I have a FvwmButtons module, which i want to be “on bottom” most of the time, but i need it to pop over all other windows when i press one of its buttons.
i seem not to be able to change style of that module (when i press the button, nothing happens), can anyone help? here’s the code i have:
(i tried it with StaysOnBottom/StaysOnTop with same (=no) effect)
The problem is in your understanding of what a command is in FVWM. The above line says the immediately, the function is to run some command “Dash”, which is stupid because there is no command. You really mean:
crap, i copy-pasted it incorrectly, nevermind
i tried what you’ve suggested
+ I ThisWindow (Dash) Layer 10
but i get the same problem, nothing happens, the window stays in layer 0. couldn’t there be some conflict between what i’m trying to do and style of that module? (all those neverfocus, windowlistskip etc.)?
