Cinnamon-like / Aerosnap tiling finction
I’m trying to write a Cinnamon-like pseudo tiling function which makes use of the keyboard to quickly resize and move windows to and from various fixed positions, with window states 1-9 representing the positions as they would on a numpad I.E. 1 = lower-left corner; 9 = upper-right corner; 2 = bottom half of screen; 8 = top half of screen; 6 = right half of screen; 3 = bottom-right corner; etc.
In theory it should work like this:
WinKey + Arrow = Tiles window to given part of the screen (Another arrow moves window to next tiled position or untiles and returns window to original position, depending on given direction)
So far I am able put the windows into, and return to the original position from, positions 2, 4, 6, 8, I.E. all the “half screen” positions.
But I cannot reliably get the corner positions to work (1,3,7,9). Sometimes the windows go into those positions, sometimes not, and even if they do, it is not always the corner I designate, nor does it “come out” of the corner.
As an illustration, I can put the window into position 6 (right half of screen), and then move it down into position 3 (bottom-right corner), but then it just gets stuck there. Also, If I put a window into position 4 (left-half of screen) and move it down into position 1 (bottom-left of screen) it jumps to position 3 (bottom-right of screen). I can’t work out what is wrong.
(I have used ResizeMoveMaximize in order to have the ability to return the window to it’s original position, and have designated “State 5” to be used for all windows being tiled, so my other windows are not interfered with.)
Here are my functions]
DestroyFunc TileLeft
AddToFunc TileLeft
if tiled and tiled left (up, middle or down) then do nothing
  • I Current (State 5, State 1) Break
  • I Current (State 5, State 4) Break
  • I Current (State 5, State 7) Break
If not tiled, tile left, give tiled state and tiled left state
  • I Current (!State 5, !Maximized) ResizeMoveMaximize 50 100 0 0
  • I Current (!State 5) State 4
  • I Current (!State 5) State 5
  • I TestRc (Match) Break
If tiled right, then untile and remove tiled states
  • I Current (State 5, State 6) Maximize False
  • I State 6 False
  • I State 5 False
If tiled up, then tile top-left
  • I Current (State 5, State 8) Maximize False
  • I State 8 False
  • I State 7 True
  • I Current (State 7) ResizeMoveMaximize 50 50 0 0
If tiled bottom, then tile bottom-left
  • I Current (State 5, State 2) Maximize False
  • I State 2 False
  • I State 1 True
  • I Current (State 1) ResizeMoveMaximize 50 50 0 50
If tiled top-right, then tile top
  • I Current (State 5, State 9) Maximize False
  • I State 9 False
  • I State 8 True
  • I Current (State 8) ResizeMoveMaximize 100 50 0 0
If tiled bottom-right, then tile bottom
  • I Current (State 5, State 3) Maximize False
  • I State 3 False
  • I State 2 True
  • I Current (State 2) ResizeMoveMaximize 100 50 0 50
    Key Left A 4 TileLeft
DestroyFunc TileRight
AddToFunc TileRight
if tiled and tiled right (up, middle or down) then do nothing
  • I Current (State 5, State 3) Break
  • I Current (State 5, State 6) Break
  • I Current (State 5, State 9) Break
If not tiled, tile right, give tiled state and tiled right state
  • I Current (!State 5, !Maximized) ResizeMoveMaximize 50 100 50 0
  • I Current (!State 5) State 6
If tiled left, then untile and remove tiled states
  • I Current (State 5, State 4) Maximize False
  • I State 4 False
  • I State 5 False
If tiled top, then tile top-right
  • I State 8 False
  • I State 9 True
  • I Current (State 9) ResizeMoveMaximize 50 50 50 0
If tiled bottom, then tile bottom-right
  • I State 2 False
  • I State 3 True
  • I Current (State 3) ResizeMoveMaximize 50 50 50 50
If tiled top-left, then tile top
  • I Current (State 5, State 7) Maximize False
  • I State 7 False
  • I State 8 True
If tiled bottom-left, then tile bottom
  • I Current (State 5, State 1) Maximize False
  • I State 1 False
  • I State 2 True
    Key Right A 4 TileRight
DestroyFunc TileUp
AddToFunc TileUp
if tiled and tiled up (left, middle or right) then do nothing
  • I Current (State 5, State 8) Break
If not tiled, tile up, give tiled state and tiled up state
  • I Current (!State 5, !Maximized) ResizeMoveMaximize 100 50 0 0
  • I Current (!State 5) State 8
If tiled down, then untile and remove tiled states
  • I State 2 False
  • I State 5 False
If tiled right, then tile top-right
  • I State 6 False
  • I State 9 True
If tiled left, then tile top-left
  • I State 4 False
  • I State 7 True
If tiled bottom-right, then tile right
  • I State 3 False
  • I State 6 True
  • I Current (State 6) ResizeMoveMaximize 50 100 50 0
If tiled bottom-left, then tile left
  • I State 1 False
  • I State 4 True
  • I Current (State 4) ResizeMoveMaximize 50 100 0 0
    Key Up A 4 TileUp
DestroyFunc TileDown
AddToFunc TileDown
if tiled and tiled down (left, middle or right) then do nothing
  • I Current (State 5, State 2) Break
If not tiled, tile down, give tiled state and tiled down state
  • I Current (!State 5, !Maximized) ResizeMoveMaximize 100 50 0 50
  • I Current (!State 5) State 2
If tiled up, then untile and remove tiled states
  • I State 8 False
  • I State 5 False
If tiled right, then tile bottom-right
  • I State 6 False
  • I State 3 True
If tiled left, then tile bottom-left
  • I State 4 False
  • I State 1 True
If tiled top-right, then tile right
  • I State 9 False
  • I State 6 True
If tiled top-left, then tile left
  • I State 7 False
  • I State 4 True
    Key Down A 4 TileDown
Any help is much appreciated. Thanks.
Hallo, n0nr4nd0m,
I hope you haven’t lost patience yet. Your “stateful” logic is, in fact, wrong. I didn’t overlook it completely, but when I follow your given example, first to 6 and from there to 3, I really end up with a State 3 set but a State 5 unset, i. e. you’re stuck.
You must simplify this logic somehow. My suggestion is to write three more functions, “ClearBits”, “UnTile” and “Tile”.
  • ClearBits clears all State bits, including no. 5
  • UnTile calls ClearBits and unmaximizes the window
  • Tile serves to freshly tile or to re-tile a window. It gets 5 arguments: the wanted State number and the 4 parameters for ResizeMoveMaximize. It calls ClearBits, sets State 5, sets State $0 and calls ResizeMoveMaximize. You can call ResizeMoveMaximize for an already maximized window btw., no need to unmaximize first.
    Your four functions TileLeft etc. only decide whether to Break or to call Tile or UnTile.
    This doesn’t make it shorter but better to debug.
I’ve finally got round to doing it. Works fine. Here is what I’ve got:
[code]DestroyFunc TileFunc
AddToFunc TileFunc
  • I Function ClearTileStatesFunc
  • I State $0 True
  • I ResizeMoveMaximize Frame $1 $2 $3 $4
DestroyFunc ClearTileStatesFunc
AddToFunc ClearTileStatesFunc
  • I State 1 False
  • I State 2 False
  • I State 3 False
  • I State 4 False
  • I State 5 False
  • I State 6 False
  • I State 7 False
  • I State 8 False
  • I State 9 False
DestroyFunc UnTileFunc
AddToFunc UnTileFunc
  • I Maximize False
DestroyFunc TileLeftFunc
AddToFunc TileLeftFunc
if not tiled, tile left
  • I Current (!State 1, !State 2, !State 3, !State 4, !State 5, !State 6, !State 7, !State 8, !State 9, !State 10) Function TileFunc 4 50 100 0 0
if tiled bottom-left, do nothing
  • I Current (State 1) Break
if tiled bottom, then tile bottom-left
  • I Current (State 2) Function TileFunc 1 50 50 0 50
  • I State 2 False
if tiled bottom-right, then tile bottom
  • I Current (State 3) Function TileFunc 2 100 50 0 50
  • I State 3 False
if tiled left, do nothing
  • I Current (State 4) Function TileFunc 4 25 100 0 0
if tiled middle, tile left
  • I Current (State 5) Function TileFunc 4 50 100 0 0
  • I State 5 False
if tiled right, then untile and remove tiled states
  • I Current (State 6) Function UnTileFunc
if tiled top-left, do nothing
  • I Current (State 7) Break
if tiled up, then tile top-left
  • I Current (State 8) Function TileFunc 7 50 50 0 0
  • I State 8 False
if tiled top-right, then tile top
  • I Current (State 9) Function TileFunc 8 100 50 0 0
  • I State 9 False
DestroyFunc TileRightFunc
AddToFunc TileRightFunc
if not tiled, tile right
  • I Current (!State 1, !State 2, !State 3, !State 4, !State 5, !State 6, !State 7, !State 8, !State 9, !State 10) Function TileFunc 6 50 100 50 0
if tiled bottom-left, tile to bottom
  • I Current (State 1) Function TileFunc 2 100 50 0 50
  • I State 1 False
if tiled bottom, then tile bottom-right
  • I Current (State 2) Function TileFunc 3 50 50 50 50
  • I State 2 False
if tiled bottom-right, then do nothing
  • I Current (State 3) Break
if tiled left, then untile
  • I Current (State 4) Function UnTileFunc
if tiled middle, tile right
  • I Current (State 5) Function TileFunc 6 50 100 50 0
  • I State 5 False
if tiled right, then do nothing
  • I Current (State 6) Function TileFunc 6 25 100 75 0
if tiled top-left, then tile top
  • I Current (State 7) Function TileFunc 8 100 50 0 0
if tiled up, then tile top-right
  • I Current (State 8) Function TileFunc 9 50 50 50 0
  • I State 8 False
if tiled top-right, then do nothing
  • I Current (State 9) Break
DestroyFunc TileUpFunc
AddToFunc TileUpFunc
if not tiled, tile up
  • I Current (!State 1, !State 2, !State 3, !State 4, !State 5, !State 6, !State 7, !State 8, !State 9, !State 10) Function TileFunc 5 100 100 0 0
if tiled bottom-left, tile to left
  • I Current (State 1) Function TileFunc 4 50 100 0 0
  • I State 1 False
if tiled bottom, then untile
  • I Current (State 2) Function UnTileFunc
if tiled bottom-right, then tile right
  • I Current (State 3) Function TileFunc 6 50 100 50 0
  • I State 3 False
if tiled left, then tile top left
  • I Current (State 4) Function TileFunc 7 50 50 0 0
  • I State 4 False
if tiled middle, tile up
  • I Current (State 5) Function TileFunc 8 100 50 0 0
  • I State 5 False
if tiled right, then tile top right
  • I Current (State 6) Function TileFunc 9 50 50 50 0
  • I State 6 False
if tiled top-left, then do nothing
if tiled up, then do nothing
  • I Current (State 8) Break
if tiled fullscreen, then tile top
  • I State 5 False
DestroyFunc TileDownFunc
AddToFunc TileDownFunc
if not tiled, tile down
  • I Current (!State 1, !State 2, !State 3, !State 4, !State 5, !State 6, !State 7, !State 8, !State 9, !State 10) Function TileFunc 2 100 50 0 50
if tiled bottom, do nothing
  • I Current (State 2) Break
if tiled left, then tile bottom left
  • I Current (State 4) Function TileFunc 1 50 50 0 50
  • I State 4 False
if tiled middle, tile down
  • I Current (State 5) Function UnTileFunc
  • I State 5 False
if tiled right, then tile bottom right
  • I Current (State 6) Function TileFunc 3 50 50 50 50
  • I State 6 False
if tiled top-left, then tile left
  • I Current (State 7) Function TileFunc 4 50 100 0 0
  • I State 7 False
if tiled up, then tile to fullscreen
  • I Current (State 8) Function TileFunc 5 100 100 0 0
  • I State 8 False
if tiled top-right, then tile right
  • I Current (State 9) Function TileFunc 6 50 100 50 0
  • I State 9 False
