Okay, I have finished my theme finally! Many thanks to all the wonderful people on IRC that have helped me.
I posted my config on DeviantArt, so you can download it from here, and you can also my notes on the screenshot on it’s flickr page.
Here’s a small screenshot to give you an idea what it looks like while my huge 1600x1200 screenies are loading elsewhere
You need the patch from frogb, but in the .fvwm2rc, just put:
Style * RoundedCorners
That’s it!
And if you don’t want them on certain windows, just put:
Style myspecialprog !RoundedCorners
Can you please post your config for your taskbar? I would like to set up something like that, I haven’t succeded to make tray work yet, and it seems your taskbar has tray.
You can PM me or send me an email if you don’t want to put configs for public.
I have had problems with tray apps for some reason. I tried trayer, but whenever it acquired a new icon, it would unswallow itself and need a restart of Fvwm to get it back. The same kind of thing happens with lxpanel (the program I’m using now), but only when I change a config setting of the panel, so it’s bearable. Any ideas are welcome.
