Hey all –
Anyone know how to make FVWM close one of the active applications if it loses focus?
I want to have an application open until it loses focus, and then have it be closed…
thanks in advance,
Skender
Hey all –
thanks in advance,
Skender
You want to check out FvwmEvent to do that, it allows you te react on certain events that happen to windows, I haven’t used it myself yet, but the a look at the manpage or a search on the forum will certainly prove worthwile
As tBD says, FvwmEvent can be used. You might also be able to do it with FvwmAuto:
Module FvwmAuto 0 -mleave "Silent Close"
