Yes, but you have short cuts to the keys in that menu.
img231.imageshack.us/my.php?image=notepader2.jpg
I was using MultiEdit back in the 80’s
Here is a list about the shortcuts i can access without ever leaving the “Insert-mode”
img153.imageshack.us/my.php?image=meov7.jpg
Thats what this editor could do back then, with a bunch of macros to dl and a possibility to record new macros.
I bet that MultiEdit Today is worth to compare with Emacs and Vi(m), and you can do all the work there in without Ever leave the “Insertt-Mode” and also without ever click on any of the menus.
It Even have a Emacs Macro-File, but i can not tell how close that comes.
And yes - it’s commercial and costs a lot of money and … thats another thread.
I will look at both of them, - but i dubt that i will change my opinion here .- and why should i.?
I have to agree that some keybindings in vi(m) are very powerful - dd dw, some others slows me down - d$ for example - in a Swedish keyboard i have to press <alt+gr> to reach the $ sign.
that gives five keys, if i count the and keys.
i am used to - continue typing.
And i think that my question from the start was lost here.
What i want i to know is if i can make some aliases thats tells vim the follwing…
if i hit <shift+anycursorkey> - then vim should jump out of “insert-mode” and mark the block i select with the cursor until i release the shiftkey, then it should jump into insert mode until i press <shift+insert> then it should paste the text
i know that i in vim can press the keys /<ctrl+v> (move to where to paste the selection),
then i can continue write the text.
And what i want to do is <shift+arrowkeyr> <ctrl+ins> (move to where to paste the selection),
<shift+insert>
Yes, there are one key press more in the “m$-style” (that term is wrong, micro$oft adopted the style when it have been a de-facto standard for quite long, that was the days before win 3.0)
but there are fewer hand-movements.
Then, if i should use the vim-style editing,- or the “ms-style” (quotes because the term is wrong),
thats more a philosophic / religious question.
What i want to know - is it possible to completely remap the keys in that way i am asking for.?
/Dante
