This module + scripts allows you to control Xorg’s Composite features under Fvwm.
I aquired it off another forum a long time ago and have noticed any links to such are currently broken.
I paste it now for the bennefit of others and, hopefully, contributions/improvements will arise.
There is another post about this on this forum which has some instructions.
viewtopic.php?t=27&start=0&postdays=0&postorder=asc&highlight=
I have modified the scripts from the original posting, but changes were only slight.
I believe I changed the default transparency for new windows and made some changes to settrans.pl that affected how fluidly it changes transparency.
I also changed the application used in settrans.pl from transset to transset-df
“FvwmTransset”
#!/usr/bin/perl
use lib `fvwm-perllib dir`;
use FVWM::Module;
my $module = new FVWM::Module;
# Get to the right directory;
chdir;
my $defaultsFile = ".fvwm/trans.defaults" or die "No config file";
my $tempFile = ".fvwm/trans.temp";
# Clean out temporary file in preparation
# to run
sub startup
my $cmd = "rm -f " . $tempFile;
system($cmd);
$cmd = "touch " . $tempFile;
system($cmd);
# Called by FVWM for every created window
sub onWindowCreate
my $win_id = $_[1]->_win_id;
$win_id = oct($win_id) if $win_id =~ /^0/;
my $trans = 0.90; # Default transparency of 0.95 on all windows
open(DEFAULTS, "<", $defaultsFile);
while(my $line = <DEFAULTS>)
# Token 0 is the window property to match against
# Token 1 is the value to match
# Token 2 is the default transparency level
chomp($line);
my @tokens = split(/:/, $line);
# Each iteration checks to see if the supplied variable is defined
# for this window via xprop, and then checks to see if the matching
# criteria is met, if it is, use that transparency
my $test = "xprop -id " . $win_id . " | grep " . @tokens[0];
my $result = `$test`;
if($result =~ m/@tokens[1]/)
$trans = @tokens[2];
# Don't bother with the other lines
break;
close(DEFAULTS);
if($trans < 1.0)
my $tempEntry = $win_id . ":" . $trans;
open(TEMP, ">>", $tempFile);
print TEMP $tempEntry . "\n";
close(TEMP);
#my $ex = "transset-df " . $trans . " -id " . $win_id;
print "Trying to set transparency with: " . $ex . "\n";
system("transset-df","-i",$win_id,$trans);
#system($ex);
sub onWindowDestroy
open(TEMP, "<", $tempFile);
my %transHash;
while(my $line = <TEMP>)
my @temp = split(/:/, $line);
$transHash{@temp[0]} = @temp[1];
close(TEMP);
delete($transHash{$win_id});
open(TEMP, ">", $tempFile);
# Re-output the whole temp file, with new value
my @keys = keys %transHash;
my @values = values %transHash;
while(@keys)
my $temp = pop(@keys) . ":" . pop(@values);
print TEMP $temp;
close(TEMP);
startup();
$module->addHandler(M_ADD_WINDOW, \&onWindowCreate);
$module->addHandler(M_DESTROY_WINDOW, \&onWindowDestroy);
$module->eventLoop;
“settrans.pl”
#!/usr/bin/perl
# Arguments:
# 1) A window ID in hex or decimal
# 2) Either "+" or "-" (without quotes)
# Indicates direction of transparency stepping,
# and steps by 5
# + Means make more transparent ($trans -= 5)
# - Means make less transparent ($trans += 5)
my $win_id = @ARGV[0];
my $direction = @ARGV[1];
my $tempFile = "/dev/shm/trans.temp";
if((($direction ne "+") && ($direction ne "-")))
die "Wrong arguments\n";
chdir;
# Transparency levels keyed by window ID
my %transHash;
chomp($line);
close(TEMP);
# Make less transparent
if($direction eq "-")
# If the window isn't transparent (according to temp file)
# then just quit out (die), since it can't really be less transparent
if(!defined($transHash{$win_id}))
die $win_id . " already fully opaque\n";
$trans = $transHash{$win_id};
if($trans < 1.0)
$trans += 0.05;
# Make more transparent
else
$trans = 0.95;
else
if($trans > 0.1)
$trans -= 0.05;
#my $cmd = "transset-df " . $trans . " -id " . $win_id;
#system($cmd);
# Update the hash with the new value
$transHash{$win_id} = $trans;
while(@keys)
my $temp = pop(@keys) . ":" . pop(@values) . "\n";
print TEMP $temp;
close(TEMP);
“trans.defaults”
WM_NAME:Lists de contacts:0.7
WM_CLASS:rxvt:0.5
WM_CLASS:psi:0.8
WM_RESOURCE:urxvt:0.5
WM_CLASS:Pympd:0.6
FvwmTransset goes in your fvwm modules dir
settrans.pl and trans.defaults go in ~/.fvwm/
I use transset-df to manualy modify the transparency of my windows
Mouse 4 W CM Exec exec transset-df -p --inc 0.1
Mouse 5 W CM Exec exec transset-df --min 0.1 -p --dec 0.1
