Could Someone Give me Advice on FVWM Configuration for Multi-Monitor Setup?
Hello there,
I am reaching out for some guidance on setting up FVWM with a multi-monitor configuration. I have recently transitioned to using FVWM as my window manager and am keen on customizing it to suit my multi-monitor setup.
I want to configure FVWM to use the entire screen real estate effectively. How can I ensure that my desktop background and workspace span across both monitors seamlessly? :thinking: I am looking to replicate a setup where both monitors act as one large continuous workspace.
I would like to have consistent window placement rules across both monitors. For instance, how can I set up rules so that certain applications always open on a specific monitor or in a specific area? :thinking:
I am interested in setting up a panel or taskbar that spans both monitors. What are the best practices for configuring FVWM panels to work across multiple displays? :thinking:
Also, I have gone through this post; https://fvwmforums.org/t/ewmhbasestruts-in-a-multi-monitor-setup-mlops/ which definitely helped me out a lot.
Are there any tips for optimizing FVWM’s performance in a multi-monitor environment? I’m particularly interested in any known tweaks or configurations that can enhance smoothness and responsiveness.
Thanks in advance for your help and assistance. :innocent:
For workspace make sure that DesktopConfiguration is set to global. (See DesktopConfiguration for more information)
For desktop background you will need to use a tool like feh or nitrogen (probably nitrogen).
Yes. Use the style command. For instance:
Style foo StartsOnScreen HDMI-1
Style bar StartsOnScreen eDP
Use the style command and take a look at the PositionPlacement and Geometry options
Create a panel that has a geometry that covers both monitors, or use something like lemonbar or polybar.
What do you mean exactly?
