hi all,
i want to deactivate standard “Builtin Menu”, where is this file located ?
I have already disabled the menu from fvwm-themes etc. , but i cant find the standard menu.
FVWM Version:
FVWM-2.5.1.3 (Unstable)
FVWM-THEMES-0.7.0
FVWM-THEMES-EXTRA-0.4.0
R4R
Just bind something else to those mousebuttons, like:
Mouse 1 R A Nop
to have the button do nothing on click.
how and where ? can you say me the exact command ?
The command theBlackDragon showed you is the correct command. Just add it to your .fvwm2rc file. If you really want to check it is accurate before you “commit” it, type it into FVwmConsole, to see, first.
big thanks
it works fine !
