Hi.
Since no one replied to this I guess I need to elaborate. A snip from my config:
#Functions:
DestroyFunc toggleiconify-and-raise
AddToFunc toggleiconify-and-raise
+ I Iconify toggle
+ I Raise
#Keybindings
Key Tab A C Next [iconic] Focus
Key Tab A CM toggleiconify-and-raise
Key Tab A M Next [CurrentPage !iconic] Focus
#An IconMan swallowed by a panel at the right side of the screen
DestroyModuleConfig IMSideBar: *
*IMSideBar: ShowOnlyIcons True
*IMSideBar: Colorset 8
*IMSideBar: SelectColorset 9
*IMSideBar: FocusColorset 9
*IMSideBar: Title ""
*IMSideBar: ButtonGeometry 24x24
*IMSideBar: DrawIcons Always
*IMSideBar: ManagerGeometry 1x1
*IMSideBar: ReliefThickness 1
*IMSideBar: Resolution Global
*IMSideBar: Format "%c"
*IMSideBar: Sort id
In short: Ctrl+Tab cycles the iconified windows which are show in the sidebar and on the root window. Ctrl+Meta+Tab deiconifies a selected/focused icon or iconifies the window in focus.
I would like to have the exact same behaviour, but no icons showing on the root window. If I useStyle * NoIcon
no icons will not appear on the root window, only in the IconMan. However, it is no longer possible to select iconified windows with Next (iconified) Iconify toggle...
Just now I started wondering whethter this is a bug? It seems that a window can only be in the iconified state if it has an icon. I don’t see why a window cannot be iconified and have an empty/no icon. Well, it could be that I’ve missed a window state.
I’ve tried programming the IconMan to solve my problem of the missing window state, but I can’t quite get the last details right:
#Select next iconified window on Ctrl+Tab:
Key Tab A C SendToModule IMSideBar bif select 3, gotobutton 0, select, ret, bif Next 3, gotobutton 0, select, ret, gotobutton Next, select
#Call a function to de/iconify
Key Tab A C iconify-iconman
DestroyFunc iconify-iconman
AddToFunc iconify-iconman
+ I SendToModule IMSideBar bif select 1, ret, sendcommand "Iconify -1", sendcommand Raise, sendcommand Focus
The function “iconify-iconman” only works partially. After deiconifying, the IconMan automatically selects the next (down) icon, unless it was the lowest icon that got deiconified. This leaves me with two things focused: the current window and a window in the IconMan. Is there a way to clear the selection in an IconMan?
The last thing I need is the ability to test whether a window in the IconMan has been selected. Something like:[code]DestroyFunc iconify-iconman
- I SendToModule IMSideBar bif select 1, ret, sendcommand “Iconify -1”, sendcommand Raise, sendcommand Focus
- I ‘If no window was selected in the iconman, iconfy the current window’[/code]
Any suggestions are appreciated.
