Hello guys!
I did a script that I swallow in a fvwnbuttons, each buttons is linked to a mount (mouse 1) ou unmount (mouse 3) action for a mountpoint specified in fstab. The aim of the script is then just to change the displayed icon according to the state of the filesystem (mounted or not). Every script takes approximately 5 Mb of Ram and since I did that I got an increase in the cpu ressources consumption (I use it for 7 different mountpoints…). The script check every second the state of the filesystem and then changes or doesn’t change the displayed icon.
So I would like to have the script being executed only when I click on the button! Any idea about how to do that??
Here is the script (one of them):
#####################begin#################
# Usage: Module FvwmScript path/to/FvwmScript-Mount-xxxxx
# state=0: unmounted, =1: mounted
WindowTitle {FvwmScript-Mount-Sounds}
WindowSize 24 24
Colorset 10
Init
Begin
Set $state_prev=-1
End
PeriodicTasks
Begin
Set $state=(GetOutput {cat /etc/mtab|grep -c sounds} 1 -1)
#ChangeTitle 1 $state
If $state==$state_prev Then
Begin
# do nothing
End
Else
Begin
Set $state_prev=$state
Set $scale=$state
Set $icon= mount/ $scale .png
#ChangeTitle 1 $icon
ChangeIcon 1 $icon
End
End
Widget 1
Property
Position 0 0
Size 24 24
Type ItemDraw
Flags NoReliefString Center
Main
Case message of
SingleClic :
Begin
End
End
###################end########################
and I call it in a Fvwmbuttons module like that:
Sounds button.
*FvwmButtons-MOUNT: (1x1, Size 24 24,
Action (Mouse 1) Exec exec mount /mnt/sounds,
Action (Mouse 3) Exec exec umount /mnt/sounds,
Swallow (Close, Respawn) “FvwmScript-Mount-Sounds”
‘Module FvwmScript $[HOME]/.fvwm/FvwmScript-Mount-Sounds’)
also, if I click on mouse 1 with an already mounted filesystem, the error-message is recorded in my .xsession-errors file, how can I avoid that?
Best regards, Brice
–> Added [code ][/code ] tags to inrease readability.[/color]
