Hello everybody,
Firstly, I’m french and don’t speak english well
I’ve installed fvwm but when I want start it, it failed.
The cursor is working all the time, and if I press a key, it failed and it puts me on the login screen again.
In the error log, it tells me “no such key”.
Thanks,
Marion
TiteFleur:
Hello everybody,
Thanks,
Marion
How do you login? Do you use a graphical login manager, or do you use ‘startx’?
I use a graphical login manager, by default with Debian Sarge, I think it’s gdm.
But this graphical login manager works good with Gnome, KDE, or Fluxbox …
I think I have a problem with my special keys : I have a Compaq laptop. But how to desactivate those or configurate ?
Sorry for my english, I don’t know if every word exists !
Thanks,
Marion.
TiteFleur:
OK.
I’m not sure – I know there’s some programs in Debian that will allow you to disable special keys. Just out of interest – when you login and fvwm starts, is CapsLock, or NumLock, or ScrollLock on?
(tu parles l’anglais tres bien)
Thanks
When it starts, no special key is activated.
So, I will try to find a program to disable the special keys !
And I will try to launch fvwm with startx.
Thanks
Marion
I think Debian uses XFree86, not x.org as most other current distros.
So your configuration should be in
/etc/X11/XF86Config-4
You can open it as root in an editor.
There is a section “Inputdevice”.
Have a look if there are special entries.
In my old XF86Config4 I used a year ago it looks like this (german keyboard)
Section “InputDevice”
Identifier “Keyboard1”
Driver “Keyboard”
Option “XkbModel” “pc105”
Option “XkbLayout” “de(nodeadkeys)”
Option “XkbOptions” “”
EndSection
I think you must replace “de” (allemand) with “fr” (francais)?
These entries worked fine with fvwm.
Bien de saluts, Mark
zonk
15 June 2005 06:38
7
After your attempt to launch fvwm failed, switch to the console (ctrl-alt-F1), log in, and look wether there are errors reported in .xession-errors.
Thanks for your answers.
Indeed, Debian uses XFree86.
I’ve tried to launch fvwm with “startx” but that did not go either.
So I will try with this configuration of the keyboard as Mu say to me.
And will look at the errors in the console.
Thanks a lot,
Marion.
Well, I’ve changed my configuration of the keyboard like you, but it’s the same error.
My .xsession-errors file :
[code]/etc/gdm/PreSession/Default: Registering your session with wtmp and utmp
/etc/gdm/PreSession/Default: running: /usr/X11R6/bin/sessreg -a -w /var/log/wtmp -u /var/run/utmp -x “/var/lib/gdm/:0.Xservers” -h “” -l “:0” “marion”
/etc/gdm/Xsession: Beginning session setup…
[FVWM][scanForPixmap]: <> Couldn’t load image from /usr/share/gnome-system-tools/pixmaps/runlevel.png
[FVWM][scanForPixmap]: <> Couldn’t load image from /usr/share/pixmaps/gnome-eog.xpm
[FVWM][parse_colorset]: <> bad colorset pixmap specifier Translucent
[FVWM][ReadDecorFace]: <> couldn’t load pixmap decoration/iconbarf.xpm
[FVWM][ReadDecorFace]: <> couldn’t load pixmap decoration/iconbaru.xpm
[FVWM][ReadDecorFace]: <> couldn’t load pixmap decoration/stick.xpm
[FVWM][ReadDecorFace]: <> couldn’t load pixmap decoration/icon.xpm
[FVWM][ReadDecorFace]: <> couldn’t load pixmap decoration/max.xpm
[FVWM][ReadDecorFace]: <> couldn’t load pixmap decoration/close.xpm
[FVWM][ParseBinding]: <> No such key: XF86AudioMute
[FVWM][ParseBinding]: <> No such key: XF86AudioRaiseVolume
[FVWM][ParseBinding]: <> No such key: XF86AudioLowerVolume
[FVWM][ParseBinding]: <> No such key: XF86AudioMedia
[FVWM][ParseBinding]: <> No such key: XF86Mail
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/gnome-terminal.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/office.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/internet.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/gvim.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/multimedia.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/utils.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/games.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/prefs.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/quit.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/oowriter.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/oocalc.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/firefox.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/thunderbird.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/xchat.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/gaim.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/gftp.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/bluefish.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/xmms.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/gimp.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/grip.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/k3b.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/mplayer.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/browse.png
[FVWM][scanForPixmap]: <> Couldn’t load image from icons/quit2.png
/bin/sh: line 1: /home/marion/.fvwm/scripts//xmodmap.sh: Aucun fichier ou répertoire de ce type
/bin/sh: line 1: exec: /home/marion/.fvwm/scripts//xmodmap.sh: cannot execute: Aucun fichier ou répertoire de ce type
FvwmBanner: ERROR finding image file in ImagePath
NULL packet: exiting[/code]
Thanks,
Marion
MU1
15 June 2005 10:15
10
You could delete/rename your Fvwm-Start(configuration)-file.
mv ~/.fvwm/.fvwm2rc ~/.fvwm/.fvwm2rc-old
Then Fvwm should start “clean” without special banner-settings or without trying to run xmodmap.sh
If this works, you can create an empty .fvwm2rc with an editor, and start copying lines from your .fvwmrc-old to the new one.
Like this you can find out the “wrong” entry.
Or you use a .fvwm2rc from this forum (Screenshots and Configs).
Mark
Yes ! It’s ok when I’ve deleted the ~/.fvwm/.fvwm2rc as you say !
I’m writing from fvwm 8)
Then, now I will try to put files of configuration !
Thank you, I will keep you informed,
Marion
MU1
15 June 2005 10:47
12
tres bien
bonne chance and lots of fun with setting up your configuration.
If it gets too difficult, install fvwm-themes.
This is an addon with many examples in a special “theme”-folder.
But also this forum has many nice configs, and you can customize your desktop better if you understand how they work
Mark
Thanks !
Indeed I have work but that should be pleasant ! I will look at this add-on and the configurations of the forum !
