Here is the diff of translucency. Just copy and save it to /usr/ports/x11-wm/fvwm2-devel/files/patch-z
then do a “make clean && make deinstall && make install”
However, it just support menu translucency.
Index: fvwm/colorset.c
RCS file: /home/cvs/fvwm/fvwm/fvwm/colorset.c,v
retrieving revision 1.45
diff -u -r1.45 colorset.c
--- fvwm/colorset.c.orig 25 Aug 2003 06:47:08 -0000 1.45
+++ fvwm/colorset.c 31 Aug 2003 19:48:14 -0000
@@ -159,7 +159,9 @@
"IconTint",
"NoIconTint",
"IconAlpha",
+ "Translucent",
+ "NoTranslucent",
NULL
@@ -616,6 +618,7 @@
char *fg_tint = NULL;
char *bg_tint = NULL;
char *icon_tint = NULL;
+ char *translucent_tint = NULL;
Bool have_pixels_changed = False;
Bool has_icon_pixels_changed = False;
Bool has_fg_changed = False;
@@ -628,6 +631,7 @@
Bool has_fg_tint_changed = False;
Bool has_bg_tint_changed = False;
Bool has_icon_tint_changed = False;
+ Bool has_translucent_tint_changed = False;
Bool has_pixmap_changed = False;
Bool has_shape_changed = False;
Bool has_image_alpha_changed = False;
@@ -754,6 +758,10 @@
case 21: /* Plain */
has_pixmap_changed = True;
free_colorset_background(cs, True);
+ cs->is_translucent = False;
+ cs->translucent_tint_percent = 0;
+ cs->color_flags &= ~TRANSLUCENT_TINT_SUPPLIED;
+ has_translucent_tint_changed = True;
break;
case 22: /* NoShape */
has_shape_changed = True;
@@ -920,6 +928,24 @@
cs->icon_alpha_percent = tmp;
break;
+ case 42: /* Translucent */
+ cs->is_translucent = True;
+ parse_simple_tint(
+ cs, args, &translucent_tint,
+ TRANSLUCENT_TINT_SUPPLIED,
+ &has_translucent_tint_changed, &percent,
+ "Translucent");
+ if (has_translucent_tint_changed)
+ cs->translucent_tint_percent = percent;
+ break;
+ case 43: /* NoTranslucent */
+ break;
default:
/* test for ?Gradient */
if (option[0] && StrEquals(&option[1], "Gradient"))
@@ -1602,6 +1628,27 @@
+ * ---------- change the translucent tint colour ----------
+ /* user specified colour */
+ if (translucent_tint != NULL)
+ PictureFreeColors(
+ dpy, Pcmap, &cs->translucent_tint, 1, 0, True);
+ cs->translucent_tint = GetColor(translucent_tint);
+ else
+ /* default */
+ cs->translucent_tint = GetColor(black);
* ---------- send new colorset to fvwm and clean up ----------
@@ -1698,6 +1745,7 @@
ncs->fgsh = GetColor(white);
ncs->tint = GetColor(black);
ncs->icon_tint = GetColor(black);
+ ncs->translucent_tint = GetColor(black);
ncs->pixmap = XCreatePixmapFromBitmapData(
dpy, Scr.NoFocusWin,
&g_bits[4 * (nColorsets % 3)], 4, 4,
@@ -1715,6 +1763,7 @@
ncs->fgsh = GetForeShadow(ncs->fg, ncs->bg);
ncs->fg_tint = ncs->bg_tint = GetColor(black);
/* set flags for fg contrast, bg average */
@@ -1726,6 +1775,7 @@
ncs->icon_alpha_percent = 100;
ncs->tint_percent = 0;
ncs->icon_tint_percent = 0;
+ ncs->translucent_tint_percent = 0;
ncs->fg_tint_percent = ncs->bg_tint_percent = 0;
ncs->dither = (PictureDitherByDefault())? True:False;
nColorsets++;
Index: fvwm/menus.c
RCS file: /home/cvs/fvwm/fvwm/fvwm/menus.c,v
retrieving revision 1.372
diff -u -r1.372 menus.c
--- fvwm/menus.c.orig 28 Aug 2003 20:26:13 -0000 1.372
+++ fvwm/menus.c 31 Aug 2003 19:48:39 -0000
@@ -65,6 +65,11 @@
/* ---------------------------- local macros ------------------------------- */
+#define MENU_IS_TRANSLUCENT(mr,cs) \
+ (!MR_IS_TEAR_OFF_MENU(mr) && CSET_IS_TRANSLUCENT(cs))
+#define MENU_IS_TRANSPARENT(mr,cs) \
+ (MENU_IS_TRANSLUCENT(mr,cs) || CSET_IS_TRANSPARENT(cs))
/* ---------------------------- imports ------------------------------------ */
/* This external is safe. It's written only during startup. */
@@ -405,7 +410,7 @@
/* move it back */
if (ST_HAS_MENU_CSET(MR_STYLE(mr)) &&
- CSET_IS_TRANSPARENT(ST_CSET_MENU(MR_STYLE(mr))))
+ MENU_IS_TRANSPARENT(mr,ST_CSET_MENU(MR_STYLE(mr))))
transparent_bg = True;
get_menu_repaint_transparent_parameters(
@@ -2419,6 +2424,7 @@
/* Doh. Use the standard display instead. */
MR_CREATE_DPY(mr) = dpy;
+ MR_IS_TEAR_OFF_MENU(mr) = 1;
else
@@ -3202,7 +3208,38 @@
MR_IS_PAINTED(mr) = 1;
/* paint the menu background */
- if (ms && ST_HAS_MENU_CSET(ms))
+ if (ms && ST_HAS_MENU_CSET(ms) &&
+ MENU_IS_TRANSLUCENT(mr,ST_CSET_MENU(ms)))
+ Pixmap trans = None;
+ FvwmRenderAttributes fra;
+ colorset_t *colorset = &Colorset[ST_CSET_MENU(ms)];
+ fra.mask = 0;
+ if (colorset->translucent_tint_percent > 0)
+ fra.mask = FRAM_HAVE_TINT;
+ fra.tint = colorset->translucent_tint;
+ fra.tint_percent = colorset->translucent_tint_percent;
+ if (MR_IS_BACKGROUND_SET(mr) == False)
+ trans = PGraphicsCreateTranslucent(
+ dpy, MR_WINDOW(mr), &fra,
+ BACK_GC(ST_MENU_INACTIVE_GCS(ms)),
+ MR_X(mr), MR_Y(mr), MR_WIDTH(mr), MR_HEIGHT(mr));
+ XMapRaised(dpy, MR_WINDOW(mr));
+ if (trans != None)
+ XSetWindowBackgroundPixmap(
+ dpy, MR_WINDOW(mr), trans);
+ MR_IS_BACKGROUND_SET(mr) = True;
+ clear_expose_menu_area(MR_WINDOW(mr), pevent);
+ XFreePixmap(dpy, trans);
+ else if (ms && ST_HAS_MENU_CSET(ms))
@@ -3996,8 +4033,8 @@
MR_XANIMATION(parent_menu) += end_x - prev_x;
if (ST_HAS_MENU_CSET(MR_STYLE(parent_menu)) &&
- ST_CSET_MENU(MR_STYLE(mr))))
+ mr,ST_CSET_MENU(MR_STYLE(mr))))
@@ -4172,10 +4209,22 @@
XMoveWindow(dpy, MR_WINDOW(mr), x, y);
+ MR_X(mr) = x;
+ MR_Y(mr) = y;
XSelectInput(dpy, MR_WINDOW(mr), event_mask);
- XMapRaised(dpy, MR_WINDOW(mr));
- if (popdown_window)
- XUnmapWindow(dpy, popdown_window);
+ if (MR_STYLE(mr) && ST_HAS_MENU_CSET(MR_STYLE(mr)) &&
+ MENU_IS_TRANSLUCENT(mr,ST_CSET_MENU(MR_STYLE(mr))))
+ if (popdown_window)
+ XUnmapWindow(dpy, popdown_window);
+ paint_menu(mr, NULL, fw);
+ else
XFlush(dpy);
MR_MAPPED_COPIES(mr)++;
MST_USAGE_COUNT(mr)++;
@@ -6589,15 +6638,45 @@
last = True;
- if (!last && CSET_IS_TRANSPARENT_PR_TINT(ST_CSET_MENU(ms)))
+ if (!last &&
+ (CSET_IS_TRANSPARENT_PR_TINT(ST_CSET_MENU(ms)) ||
+ MENU_IS_TRANSLUCENT(mr,ST_CSET_MENU(ms))))
/* too slow ... */
return;
- SetWindowBackground(
- dpy, MR_WINDOW(mr), MR_WIDTH(mr), MR_HEIGHT(mr),
- &Colorset[ST_CSET_MENU(ms)], Pdepth,
- FORE_GC(MST_MENU_INACTIVE_GCS(mr)), False);
+ if (MENU_IS_TRANSLUCENT(mr,ST_CSET_MENU(ms)))
+ Pixmap trans;
+ fra.mask = 0;
+ XUnmapWindow(dpy, MR_WINDOW(mr));
+ MR_X(mr) = x;
+ MR_Y(mr) = y;
+ else
+ SetWindowBackground(
+ dpy, MR_WINDOW(mr), MR_WIDTH(mr), MR_HEIGHT(mr),
+ &Colorset[ST_CSET_MENU(ms)], Pdepth,
+ FORE_GC(MST_MENU_INACTIVE_GCS(mr)), False);
/* redraw the background of non active item */
for (mi = MR_FIRST_ITEM(mr); mi != NULL; mi = MI_NEXT_ITEM(mi))
@@ -7230,10 +7308,12 @@
MR_HEIGHT(mr),
- Pdepth,
- True);
+ False);
+ XClearArea(
+ dpy, MR_WINDOW(mr), 0, 0, MR_WIDTH(mr),
+ MR_HEIGHT(mr), True);
else if ((ST_HAS_ACTIVE_CSET(ms) &&
ST_CSET_ACTIVE(ms) == cset) ||
Index: fvwm/menus.h
RCS file: /home/cvs/fvwm/fvwm/fvwm/menus.h,v
retrieving revision 1.103
diff -u -r1.103 menus.h
--- fvwm/menus.h.orig 28 Aug 2003 20:26:14 -0000 1.103
+++ fvwm/menus.h 31 Aug 2003 19:48:41 -0000
@@ -141,6 +141,9 @@
MenuItem *submenu_item;
/* x distance window was moved by animation */
int xanimation;
+ /* x,y XMapRaise */
+ int x;
+ int y;
/* dynamic temp flags */
struct
@@ -182,6 +185,8 @@
#define MR_SELECTED_ITEM(m) ((m)->d->selected_item)
#define MR_SUBMENU_ITEM(m) ((m)->d->submenu_item)
#define MR_XANIMATION(m) ((m)->d->xanimation)
+#define MR_X(m) ((m)->d->x)
+#define MR_Y(m) ((m)->d->y)
#define MR_STORED_ITEM(m) ((m)->d->stored_item)
#define MR_STORED_PIXELS(m) ((m)->d->stored_pixels)
/* flags */
Index: libs/Colorset.h
RCS file: /home/cvs/fvwm/fvwm/libs/Colorset.h,v
retrieving revision 1.36
diff -u -r1.36 Colorset.h
--- libs/Colorset.h.orig 29 Jun 2003 19:53:23 -0000 1.36
+++ libs/Colorset.h 31 Aug 2003 19:48:43 -0000
@@ -51,6 +51,10 @@
Bool dither;
Bool allows_buffered_transparency;
Bool is_maybe_root_transparent;
+ /* only use by fvwm menu (non tear-off) */
+ Bool is_translucent;
+ Pixel translucent_tint;
+ unsigned int translucent_tint_percent : 7;
#endif
} colorset_t;
@@ -78,6 +82,7 @@
#define FG_TINT_SUPPLIED 0x100
#define BG_TINT_SUPPLIED 0x200
#define ICON_TINT_SUPPLIED 0x400
+#define TRANSLUCENT_TINT_SUPPLIED 0x800
#endif
/* colorsets are stored as an array of structs to permit fast dereferencing */
@@ -152,6 +157,11 @@
#define CSETS_IS_TRANSPARENT_PR_TINT(cset) \
(cset >= 0 && cset->pixmap == ParentRelative && \
cset->tint_percent > 0)
+#define CSET_IS_TRANSLUCENT(cset) \
+ (cset >= 0 && Colorset[cset].is_translucent)
+#define CSETS_IS_TRANSLUCENT(cset) \
+ (cset && cset->is_translucent)
#ifndef FVWM_COLORSET_PRIVATE
/* Create n new colorsets, fvwm/colorset.c does its own thing (different size)
Index: libs/PictureGraphics.c
RCS file: /home/cvs/fvwm/fvwm/libs/PictureGraphics.c,v
retrieving revision 1.25
diff -u -r1.25 PictureGraphics.c
--- libs/PictureGraphics.c.orig 27 Aug 2003 13:37:04 -0000 1.25
+++ libs/PictureGraphics.c 31 Aug 2003 19:48:50 -0000
@@ -1338,7 +1338,7 @@
-#if 0 /* humm... maybe usefull one day with menus */
+#if 1 /* humm... maybe usefull one day with menus */
Pixmap PGraphicsCreateTranslucent(
Display *dpy, Window win, FvwmRenderAttributes *fra, GC gc,
int x, int y, int width, int height)
Index: libs/PictureGraphics.h
RCS file: /home/cvs/fvwm/fvwm/libs/PictureGraphics.h,v
retrieving revision 1.12
diff -u -r1.12 PictureGraphics.h
--- libs/PictureGraphics.h.orig 29 Jun 2003 19:53:24 -0000 1.12
+++ libs/PictureGraphics.h 31 Aug 2003 19:48:50 -0000
@@ -122,7 +122,9 @@
Display *dpy, Window win, Pixel tint, int tint_percent,
Drawable dest, Bool dest_is_a_window, GC gc, GC mono_gc, GC alpha_gc,
int dest_x, int dest_y, int dest_w, int dest_h);
+Pixmap PGraphicsCreateTranslucent(
+ Display *dpy, Window win, FvwmRenderAttributes *fra, GC gc,
+ int x, int y, int width, int height);
/* never used ! */
Pixmap PGraphicsCreateDitherPixmap(
Display *dpy, Window win, Drawable src, Pixmap mask, int depth, GC gc,
Enjoy!
