I was wondering if it was possible to, when dragging something (like a file from ROX or Nautilus to the GIMP), have fvwmiconman automatically raise the window you select on the “taskbar” like in, say, Windows.
I mean…when a maximized window holds the contents I want to drag&drop, there is no way for me to change that window (alt+tab won’t work?) to the other I want to drop the content in (say GIMP).
Can anyone help me with this?
Thanks in advance.
Not that I am aware of, no. Firstly, the application has to support D&D – XD&D is of limited support in FVWM – you can see the ‘FvwmDragWell’ module for that.
