Hello,
I am having issues trying to make fvwm and ratpoison work together. I can’t really say where the problem lies and I have no idea if it is fvwm that is the culprit. This is just a pure x-based dual head configuration. No xinerama, no twinview.
I use fvwm in the main head. But I have a smaller one I’d like to use with moc and some monitoring tools like htop, ntop and lots of tail -f’s. I could as well use fvwm on that head with urxvt + screen. But I wanted to try ratpoison and this seemed a good way to do it, since I will be using only text based programs on that head.
All is working fine, and I have one wm on each head. I use that .xinitrc for this purpose:
#!/bin/bash
while true
do
case "$1" in
ratpoison)
ratpoison -d:0.1 -s1
continue
wmii)
DISPLAY=":0.1" wmii
continue
fluxbox)
fluxbox -display :0.1 -screen 1
continue
FVWM_USERDIR=$HOME/.fvwm0 fvwm \
-s -d :0.1 -f ~/.fvwm0/config
continue
esac
done&
FVWM_USERDIR=$HOME/.fvwm dbus-launch --exit-with-session --sh-syntax \
fvwm -s -d :0.0 &>~/logs/fvwm.log 2>&1
As you see, it just defaults to fvwm if I just use startx. And it will boot any other wm if a case clause is included for it. So, I just fire up “startx ratpoison” to get fvwm+ratpoison".
The problem is that, even if both wm’s load ok (I can perfectly see the slim ratpoison interface loading and the background also sets ok from .ratpoisonrc) ratpoison seems not to react to key bindings, like C-t ?, which is a built-in. Further tests, showed that those bindings are going to fvwm. I can’t explain why, since the mouse is on the ratpoison screen, and the focus should be there as well.
I am suspecting it is indeed some kind of weird focus issue. Changing focus policy on fvwm did nothing (as I already suspected beforehand).
I tried to open a terminal on ratpoison (which I have configured to C-t t) and to my surprise, a new tab was spanwned instead on the seamonkey session on the fvwm desktop (the pointer continues on the ratpoison desktop). So, having no way to send key strokes to ratpoison, renders it completely unusable.
I don’t really know if this is an fvwm, ratpoison or X thing, or where to start looking for info. For now, Googleing has probed unsuccessful. I will continue…
Thanks in advance for any help.
