I’ve got a problem with f-spot and its fullscreen mode. I only get a window, just like any other with window decorations and everything. It’s almost the same thing with the slideshow function but that window doesn’t have a titlebar and it’s also displaced (probably because of my EwmhBaseStruts setting). Another thing is that f-spot doesn’t place itself on top of all other windows. Fullscreen in other applications like mplayer and eog works just fine.
I guess I could set a style for each window in fullscreen mode but is there a general solution to place these windows on top of all other, make them undecorated and place them in the top left corner? It would be good if I didn’t have to write a new style for each application and/or window that behaves like this.
And another fullscreen related question: Right now I can move some fullscreen windows around and switch to other windows (using alt + tab). Can I in some way disable these things for fullscreened windows (not just f-spot)?
Make the rox pinboard in fullscreen when I begin it.
To use or remove the decor :
Style "your_appli" NoTitle
or
Style "your_appli" Title
or if you want to specify the decor
Style "your_appli" UseDecor "Decor_name"
Now, you can adapt it.
With your little problem with the maximize window and alt tab, you have to make your function.
There is a lot of them in this forum, and you’ll just have to put in the function :
I Next (!maximized) FlipFocus
I didn’t try it, but with that you can find it ^^
good luck, I hope I helped you.
EDIT : spelling mistakes and !maximise => !maximized
