hello all,
I’m now configuring my fvwm setup, and I’m missing a few things
- how can I make windowList work the same as windows, order wize ?
- how can I make a certain program to open and then close on startup ?
- can I make FvwmIconMan disply icons in a certain box in a certain size
and then scrolls when there’s too many icons to fit ?
thanx[/url]
Hello.
fvwm.org/documentation/faq/#3.3 is going to help you there. You might also want to look at using FvwmProxy as well.
fvwm.org/documentation/faq/#3.18
Probably – see the ButtonGeometry option to FwwmIconMan, but it is going to be more work than just that alone.
