I’m a newbie here. Don’t know much about FVWM, but I’ve been tasked with trying to make it work in our environment, so any help is much appreciated.
I’m currently trying to get FVWM 2.4.19-1 (from the RPM distribution) up and going under CentOS 4.5. The problem I’m having is also under a stripped down custom install from Anaconda. I may be missing some essential RPMs that FVWM needs. I don’t know.
I’m also running under VMWare while debugging.
When I execute “startx” and FVWM is getting started via /root/.xinitrc, I get the following message…
6591 Floating point exception/usr/bin/fvwm2
And I’ve seen the same behavior when trying 2.5.13-1 as well.
any ideas what I’m screwing up?
Thank you.
Tim
