hi,
i wrote this posting in hope for some advice with tabbing in fvwm.
i loved tabbing in fluxbox, but i switched to fvwm and now i am looking for reasonable tabbing with fvwm with fvwmtabs. the first problem i have is that with
'NewTabber'
in my FvwmButtons i start 2 (!) tabs for some reason. i have no clue why. did not change anything in the config file. the second thing is that i have first to start a tab and then can add multiple windows (
MultiAddTab
) by clicking the buttons and then the windows…nothing compared to drag and drop with fluxbox. the handling with fvwmtabs is just pretty bad by default.
i hope that someone can give me some advice for optimising the handling. i am pretty sure, that some of you use fvwmtabs and have modified it to satisfy your needs. or maybe someone knows any alternatives.
thank you in advance,
homry
