Is there a way to make sure that every new window gets focus? I have
Style * ClickToFocus
Style * FPGrabFocus, FPReleaseFocus
Style * FPGrabFocusTransient, FPReleaseFocusTransient
but when I for example download a file in Firefox, the second dialog, Save As, doesn’t get focus.
mntnoe:
That will work fine – check you’ve got no other conflicting style lines. Perhaps upload your entire config somewhere for me to check.
Firefox will still act this way with an fvwm2rc consisting only of these three lines.
On my system at least…
Not on mine, which is correct – the style lines are doing everything as I would expect. Which leads me to wonder:
What version of FVWM you’re using.
And possibly what version of FF you’re using, not that it makes any difference really.
Ah, I use firefox’s own file picker. Perhaps it’s just a bug in the file picker then.
fvwm --version:
fvwm 2.5.18 compiled on May 26 2007 at 17:35:13
with support for: ReadLine, XPM, PNG, Shape, XShm, SM, XRender, XFT
emerge -pv fvwm:
x11-wm/fvwm-2.5.18-r1 USE="gtk perl png readline truetype -bidi -debug -imlib -nls -rplay -stroke -tk -xinerama"
emerge -pv mozilla-firefox:
www-client/mozilla-firefox-2.0.0.4 USE="filepicker java moznopango -bindist -debug -gnome -ipv6 -mozdevelop -restrict-javascript -xforms -xinerama -xprint"
mntnoe:
fvwm --version:
emerge -pv fvwm:
Well, why aren’t you using 2.5.21? And, what does the output from xprop(1) tell you about this file picker?
2.5.18 is the latest version marked stable on gentoo. I tried it on a snapshot (2007-07-02); problem persistent.
Here is the output of xprop in the given situation: http://pastebin.ca/611388
