I am seeing a small difference between the font rendering in FVWM and GTK applications.
The fonts displayed in my other applications are a little bit darker and softer than in my FVWM menu. If I take a screenshot and zoom in in gimp, I can see a difference in pixel color at the borders of the characters.
I use this to set the font:
MenuStyle * Font "xft:Liberation Sans:size=10"
Is there something I can do to get the same font rendering in FVWM as in GTK applications. The difference in rendering is small, but still annoying. I have patched the XFT and cairo libs with LCD patches (see aur.archlinux.org/packages.php?ID=16459). Could this be related to this patches?
After playing a bit with various settings, I don’t think the problem is related to how GNOME apps can use sub-pixel rendering. I have exactly the same font settings in FVWM and urxvt, but I still see a different rendering and spacing: img167.imageshack.us/my.php?image=spacingja6.png
Thus, the font rendering I would like to have in FVWM is not GTK or GNOME specific.
Does FVWM do something special with the xft font settings it gets? Do you know where I can find more specific information about how FVWM renders fonts?
Probably I was not clear enough with my explanation: I had already found the XFT section in the FVWM manual. I have tried several options to set the fonts. But for some reason, FVWM does not use my font settings in the same way as the other apps on my computer.
I still see different rendering between FVWM and my other applications.
Because GTK uses Pango? ATK? More than likely something to do with this.
But you’re not going to get the same effects as those since they’re tied into GTK. When I said you wouldn’t get the same effect, I meant: you won’t get the same effect, not “maybe if you keep asking.”
