Font $whatever - Possible? - Solved
This is my attempt:
WindowTitle {FvwmScript-Clock}
WindowSize 172 24		# Size
WindowPosition 0 0		# Position
Colorset 10
Init
 Begin
  Set $Hour=(GetOutput {date '+%a %d %b %y - %H:%M'} 1 -1)
  Set $ThemeFont = (GetOutput {echo $ThemeFont} 1 -1)
  ChangeTitle 1 $Hour
 End
PeriodicTasks
 Begin
  If (RemainderOfDiv (GetTime) 1)==0 Then
   Begin
    ChangeTitle 1 $Hour
   End
 End
Widget 1
Property
 Size 172 24
 Position 0 0
 Font $ThemeFont
 Type ItemDraw
End
The ThemeFont variable is readed and the script can see it with no problem (I checked changing $Hour by $ThemeFont in the ChangeTitle sentence), but the command Font seems not capable to expand variables, am I wrong?
In the console I just get a message telling me that the script cannot find the font “$ThemeFont”, so it seems as it can’t expand variables, or am I missing something? Im pretty new to FvwmScript so just bear with me :slight_smile:
Ah! As always, five minutes after my post I found a working solutions :slight_smile:
Colorset 10
Init
 Begin
  Set $AHour=(GetOutput {date '+%a %d %b %y - %H:%M'} 1 -1)
    ChangeFont 1 $ThemeFont
  ChangeTitle 1 $AHour
 End
PeriodicTasks
 Begin
   Begin
   End
 End
Widget 1
Property
 Size 172 24
 Position 0 0
 Type ItemDraw
End
What I do is to change the widget font in the initialization part. The problem is that now the colorset seems weird and there is a bit of flickering now and then, but that is another topic I suppose. I will post any new advance. :wink:
EDIT: The flickering was due to a boog in the script (it checked remainder of time/1, so every seccond, that with a truetype font is not a good idea, at least on my box). The weird colors was due to the fact that the font in $ThemeFont var had a shadow included into the string, I just changed the colorset and all is fine now. Topic solved.
What I did for the flicker part is to break the time into two parts, one for
the hour, the other for the minute. So every minutes, only 1 or 2 digits get
changed, and that almost eliminate the flickering.
At least in my case, even with no checks it still flickers:
PeriodicTasks
 Begin
    Set $AHour=(GetOutput {date '+%H %M %S'} 1 -1)
 End
The only workable solution here for now is to use bitmap fonts. That works smooth, of course, the aspects is not the same that you could archieve with a ttf font, but I preffer having a normal font and no flickers at all.
If you’re only showing hours and minutes, do you really need it to be exact to the second? Maybe only update the time every 15 or 30 or even 60 seconds… That will help with the flickering.
Well, the seconds are not a problem, but I like to have the two dots effect, because when Im doing weird things I relly on that to check if the box has hanged (not that that happen too often though).
I use this:
PeriodicTasks
 Begin
  If (RemainderOfDiv (GetTime) 2)==0 Then
   Begin
   End
   Else
   Begin
    Set $AHour=(GetOutput {date '+%H:%M:%S'} 1 -1)
   End
  Set $ADate=(GetOutput {date '+%d/%m/%y'} 1 -1)
  ChangeTitle 2 $ADate
 End
Wich works fine with --terminus-medium-.
Anyway, yes, you are right in one matter: if you update the clock once every minute the flickering is not so annoying, but that is because there is no redraw, the second that the thing redraws the clock still flickers. This is clearly a problem of FvwmScript with truetype fonts (all the clocks over the world that support tff can do well with them).
If you change the sh command to date ‘$S’ with ttf, does it flick?
I finally dropped the seconds and the bliking bots and the thing goes smooth. Anyway, to use the $S string I would need some sed processing (or to hava a bery big clock), which I dont think would be better in any way.
Thanks for the idea though. :wink:
Ok. I did it myself. By reducing the number of digit to refresh every seconds, the flicker is almost gone. ( As I said before )
The clock ( 11/24 19:34:52 ) is broken into 3 parts, each is a Widget:
  1. Date, 11/24
  2. Hour and Minute, 19:34:
  3. Seconds, 52
Only Widget 3 needs update every second, and it has only 2 digits.
Here is the code:
Init
Begin
  Set $tmp = (GetOutput {exec date "+%m/%d"} 1 -1)
  ChangeTitle 1 $tmp
  Set $tmp = (GetOutput {exec date "+%H:%M:"} 1 -1)
  ChangeTitle 2 $tmp
  Set $sec0 = (GetOutput {exec date "+%S"} 1 -1)
  ChangeTitle 3 $sec0
End
PeriodicTasks
Begin
  Set $sec1 = (GetOutput {exec date "+%S"} 1 -1)
  If $sec1 > $sec0 Then
  Begin
    ChangeTitle 3 $sec1
  End
  If $sec1 < $sec0 Then
  Begin
    ChangeTitle 3 $sec1
    ChangeTitle  2 $tmp
    If $tmp == {00:00:} Then
    Begin
      ChangeTitle  1 $tmp
    End
  End
  Set $sec0 = $sec1
End
