Changes in beta release 2.5.25 (26-Feb-2008)
New features:
- Handle the STATE_ADD command of the EWMH _NET_WM_STATE
message from version 1.3 of the EWMH spec. - Support transparency in ARGB windows
Bug Fixes:
- Fixed problem with windows disappearing when created
unless the style Unmanaged was used. - Edge move delay was used as resistance for the top edge.
- Fixed a parsing problem of the screen argument of the
SnapAttraction style. - Some html documentation files were not installed.
- Fixed a memory leak in internationalized font handling.
- Fixed a bug in MinOverlap placement.
- Fixed the StickyAcrossPages style in the FvwmPager.
- Fixed the determination of the X charset on UTF-8 systems.
- Fixed a crash when certain EWMH messages were sent to
unmanaged windows. - Fixed a memory leak in multibyte codepage code.
- Ignore the EWMH staysontop and staysonbottom hints if the
EWMHIgnoreStackingOrderHints style is used. - Fixed a sporadic crash when the root background set by gnome,
fvwm-root, esetroot etc. changes and a root transparent
colour set is used. - Fixed spradic crash in modules with root transparent
background from colour sets. - Fixed a possible crash if the last active module fails.
fvwm.org as usual (when the mirrors update to it, at any rate.)
