Hello,
I search FVWM for ArchLinux, and if it’s possible a patched-verison
Thanks
Hello,
Thanks
Where did you search? See: archlinux.org/packages/?q=fvwm – note that there used to be a fvwm-patched version n ArchLinux, but that’s thankfully gone the way of the dodo.
Hello
Yes I searched o the ArchLinux wiki. My first question was not well formed.
I want a patch version for Arch, because the version (patched) on the Aur is deprecated.
If I download sources for a compilation, what version I must use and what patches. There is doc or wiki for compilation?
Thanks
If you don’t know what patches, what the hell is it you think you’re going to patch, and why?
