FVWM Launch Window at Mouse Cursor?
When launching a new application or terminal or xterm or anything from a menu; it launches top right as it would if there was not even a WM running.
Is there a way (and I think I remember this from way back when I used FVWM in the 90s) to make the window outline be attached to the mouse curser until I can move it and place it somewhere?
Or if that function is a figment of my imagination; is there a way to make the window open at wherever the mouse cursor is?
I know I can choose a specific coordinate where it opens; but that is kind of worthless too for what I need.
Thanks,
T
Hi @nero
You’re looking for the ManualPlacement style option.
Kindly,
Thomas
That’s an interesting style.
Style * ManualPlacement
manual-placement
Can it be activated just for one time? Press a key and application opens with ManualPlacement.
Activate for a short time.
Schedule 10000 Style * TileCascadePlacement
Or better would be an “on and off” function.
@amlug
This is utterly incorrect. This is very error prone and works on side-effects of race conditions.
I’ll reply properly later with a better solution.
When you have time, post a solution. I am interested to know.
