I want to use this function. Is it possible to show only directories in menu ?
You could try the example from the manpage with small adaption (without engagement because not tested - no linux machine at work )]# Build a menu of all directories in
$HOME/foo
AddToMenu DirMenu foo title
- DynamicPopupAction Function MakeDirMenu
AddToFunc MakeDirMenu
- I DestroyMenu recreate DirMenu
- I AddToMenu DirMenu Directories Title
- I PipeRead ‘for i in
ls -d $HOME/Pictures/*/
do echo AddToMenu DirMenu “$i” Exec pcmanfm $i; done’[/code]
about listing directories in shell/bash I’ve found this site. Probably you need additionally a -1 in the ls call. Or try another example from that site ^^
– Thomas –
