hi all,
here is my first config I am proud of
it’s quite low on ressources, and from the included README
= fvwm config by serge Guelton
a black & white space theme
== requirements
font manu_v1.tff'' installed (
fc-cache’’ shoud do the job once the font is copied in ~/.fonts )
last version of fvwm for ``PositionPlacement Center’’ option
for use of ``urxvtc’’, urxvtd must be running: it is spawned by fvwm
== features
no menu to update
no icons to resize
only nice text
strongly uses shortcuts
very low on memory
automatic detection of window size
strongly uses urxvt for fast and low memory terms + kuake perl extension
configurable
size of font
favourite apps
== limitation
‘TimeScript’ look and feel is seperated from other file, so maintenance is limited to 2 files, but 1 would be nice
wallpaper loaded from ‘~/.wallpaper.png’
moving from urxvt to another term requires more than just a var change
zizban
3 December 2007 17:55
#2
Could you post a screen shot of the window decorations?
I’ve made a little video demo of the desktop, it is available there]http://serge.liyun.free.fr/serge/fvwm/fvwm_mint.ogg[/url]
by the way, no window decoration for this one, only keybing for quick and keyboard only manipulation
VoiDeR
4 December 2007 20:19
#4
This is the best keyboard oriented config i have ever used. Ill be using it on my old dell laptop. But I cant for the life of me get the font to work. I did what you said but i cant get it to load. The font shows up under the Firefox font preferences but under fvwm i get this error.
[fvwm][FlocaleLoadFont]: WARNING -- can't load font 'xft:manu:bold:antialias=true:size=24', trying default:
-*-fixed-medium-r-semicondensed-*-13-*-*-*-*-*-*-*,-*-fixed-medium-r-normal-*-14-*-*-*-*-*-*-*,-*-*-medium-r-normal-*-16-*-*-*-*-*-*-*
What version of FVWM are you useing and did you apply any patches over it.
Hi, first for using (and appreciating) this config !
concerning fvwm version,
$ fvwm --version
fvwm 2.5.23 compiled on Sep 22 2007 at 06:57:04
with support for: ReadLine, RPlay, Stroke, XPM, PNG, SVG, Shape, XShm, SM, Bidi text, Xinerama, XRender, XCursor, XFT, NLS
no particular patch used
for the font well … if it shows up under firefox, I can’t really tell
this post http://fvwm.lair.be/viewtopic.php?f=37&t=1719 confirms a fc-cache should be enough …
VoiDeR
5 December 2007 15:39
#6
The font problem is fixed. Some how xft support wasnt compiled in. I LOVE your config. I have put it on all 3 of my computers. My wife loves how the windows move when you close an app. Would it be possible to have to windows move in another direction? Im gonna have to read up on the animatemove function.
nice for xft ! it should always be compiled, it’s a cool feature
considering the ‘move and close’ feature, I like to throw my window to the top, but it’s up to you to change this
btw, I added the famous quake like term, F11 is the default binding (the tar is located as the same place as before)
http://serge.liyun.free.fr/serge/fvwm/fvwm_mint.tar.gz
I am also thinking of adding the following feature:
once you press Alt+E (like Email), or Alt+B (like Browser), it
tests if a browser exists, and raise / focus it / go to the good desktop
or create one
coming later !
VoiDeR
6 December 2007 12:14
#8
That sounds like a good idea. I set mine up so that when i press Alt-i the window centers then iconifys. Then when i call it back it opens up in the middle of the screen.
mmmh sounds good ! It just works for one window at once, doesn’t it ?
Thanks to your idea, I also implemented the "iconify only one window feature
I also added some ? useful ? keybinding
Alt + Left / Right / Up / Down : move current window to the left / right / up / down border.
Alt + c: re-center current window
It’s sometimes usefull, and quite funny
Moreover, the kuake console now is animated (strange bug when restarting … )
And the wallpaper is automatically scaled upon start,
really nice…very comfortable bindings…looking forward!
VoiDeR
8 December 2007 00:30
#12
Can’t wait to give it a try!
back again, for the few one who enjoy this config:
a new video showing nice animation]http://serge.liyun.free.fr/serge/fvwm/fvwm_mint-2.ogg[/url]
and the config, with a small init bug fixed; is available at
and a quick summary of the config at
note: I found that the $[vp.width] variable contains the screen width, how nice !
hope some one enjoys this
