Wasn’t sure where to post this, so moderators feel free to move it to a more appropriate location. On to the post…
I haven’t tested other versions yet, I figured I’d ask here on the forums first, but is anyone else running fvwm 2.5.12 on a ppc?
I have an iBook 1Ghz laptop on which I’m running gentoo with Fvwm as my window manager. It runs great except for one small glitch which I’ve determined only happens when I use IconTitleColorset or HilightIconTitleColorset. Regardless of whether I use thumbnails for icons or just existing images. When a program is iconified, the icon shows up somewhere near the middle of the screen (vertically) and the text under the icon shows up along the bottom border of the screen, leaving a rather large gap between the icon and text.
I only discovered the exact symptoms last night and I’m at work now, so I can’t test anything, but has anyone else noticed this problem?
Relevent config sections:
Colorset 2 Transparent, IconAlpha 50, fgAlpha 50
Style * DecorateTransient, IconBox 1280x960-0-0, IconGrid 3 3, IconFill left bottom, ForeColor #313431, IconTitleRelief 0, IconBackgroundRe
lief -1, IconTitleColorset 2, HilightIconTitleColorset 2, NoHandles, BorderWidth 1 -- flat
Removing IconTItleColorset and HilightIconTitleColorset from the config displays correctly but I’d like to be able to apply the colorset so that the interface is consistent with my x86 desktop.
Edit: Well, now I’m able to recreate the problem with the icon colorset stuff in there. I’ve split the style line up into multiple lines and so far it hasn’t happened again. I have no idea what’s wrong or what’s broken. If it happens again I’ll try to get a scaled down config that recreates the problem and then I’ll post it to the mailing list or something…
I’m still curious to know if anyone else has had this problem or other problems on ppc.
