I tried using in yours, but substitued in my colorsets. It still doesn’t work. I took the colorsets directly from taviso’s config so i assume they aren’t the problem.
I’ve got some more information that might be useful to work out what is going wrong…
When i start up fvwm, the page has no windows on it at all…
If i change to another page with the pager, the paper window and my system tray window can be seen on the selected page, but no others
If I iconify a window, the pager refreshs to fine. Goes back to how it is in 2 once i click on it.
I’ve got some more info… it seems really wierd but when i iconify a window, it shows up in the pager. When i deiconify it, the window appears full in the pager but once i grab the title bar to move it, it disappears again, and the spot where it was in icon is redrawn in the pager.
Which version of FVWM are you using? I had some weird problems with the pager, which resemble (but don’t quite match) those you describe with 2.5.10. Since I upgraded to 2.5.12 the pager works as expected.
