Configuration Information [Automatically generated, do not change]:
uname: Linux jdiamond-nb2 4.1.2 #1 SMP PREEMPT Fri Jul 17 18:16:03 ADT 2015 x86_64 Intel® Core™ i7 CPU M 620 @ 2.67GHz GenuineIntel GNU/Linux
compiler flags: gcc -Wall -Wno-implicit-int -O2 -fPIC
FVWM Version: 2.6.5
FVWM_MODULEDIR: /usr/libexec/fvwm/2.6.5
FVWM_DATADIR: /usr/share/fvwm
FVWM_USERDIR: /home/zsd/.fvwm
Description:
fvwm occasionally crashes (a few times a day).
Repeat-By:
Since I’ve started trying to take note of when it crashes,
every time it was when I was switching tabs in firefox,
opening a new tab or closing a tab (I’m currently running ffx
38.6.0esr but this crashing problem has been occurring on and
off for quite a while, so it is not specific to that
particular version of ffx). However, I’m not certain that
changing tabs in firefox is the only time it happens.
Notes: here is some of the basic information as reported by gdb
% gdb =fvwm2 ~/core
GNU gdb (GDB) 7.6.1
Copyright © 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type “show copying”
and “show warranty” for details.
This GDB was configured as “x86_64-slackware-linux”.
For bug reporting instructions, please see:
http://www.gnu.org/software/gdb/bugs/…
Reading symbols from /usr/bin/fvwm…done.
warning: core file may not match specified executable file.
[New LWP 26140]
warning: Could not load shared library symbols for linux-vdso.so.1.
Do you need “set solib-search-path” or “set sysroot”?
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib64/libthread_db.so.1”.
warning: no loadable sections found in added symbol-file system-supplied DSO at 0x7fff4afcd000
Core was generated by `/usr/bin/fvwm2’.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f23e2250dbc in free () from /lib64/libc.so.6
Traceback (most recent call last):
File “/usr/share/gdb/auto-load/usr/lib64/libgobject-2.0.so.0.3600.4-gdb.py”, line 9, in
from gobject import register
File “/usr/share/glib-2.0/gdb/gobject.py”, line 3, in
import gdb.backtrace
ImportError: No module named backtrace
(gdb) where
#1 0x00007f23e43a67a6 in XFreeStringList () from /usr/lib64/libX11.so.6
#2 0x0000000000485deb in FlocaleFreeNameProperty (ptext=ptext@entry=0x25e9710)
at Flocale.c:2358
#3 0x00000000004420ff in free_window_names (fw=fw@entry=0x25e9700,
nukename=nukename@entry=0, nukeicon=nukeicon@entry=1) at add_window.c:3171
#4 0x000000000047ffbb in EWMH_WMIconName (fw=0x25e9700,
ev=0x6d1780 <fev_event>, style=, any=)
at ewmh_names.c:175
#5 0x000000000042f110 in HandlePropertyNotify (ea=0x7fff4af29330)
at events.c:3628
#6 0x000000000042d874 in dispatch_event (e=e@entry=0x7fff4af293c0)
at events.c:4135
#7 0x000000000042e120 in HandleEvents () at events.c:4179
#8 0x000000000040b315 in main (argc=, argv=)
at fvwm.c:2591
(gdb) up
(gdb) up
at Flocale.c:2358
2358 Flocale.c: No such file or directory.
(gdb) up
3171 add_window.c: No such file or directory.
(gdb) up
at ewmh_names.c:175
175 ewmh_names.c: No such file or directory.
(gdb) up
at events.c:3628
3628 events.c: No such file or directory.
(gdb) up
at events.c:4135
4135 in events.c
(gdb) up
4179 in events.c
(gdb) up
at fvwm.c:2591
2591 fvwm.c: No such file or directory.
(gdb) quit
FWIW:
(1) I’m using Slackware64-14.1 on a Fujitsu T900 with a Core i7
M620, 8 GB of ram.
(2) I’ve let memtest86 churn away for a long time with no reported
problems. No other program on my system is showing any problems,
so while I’m not certain that it isn’t a bad hardware problem, I
don’t see any evidence of that either.
I saved a couple of core dumps. If further information from those
would be of use let me know.
Any ideas? Thanks.
