Hi all,
I have a question here. FVWM supports which type of image extension if to set a wallpaper ?
Im trying to setup wallpaper in my .fvwm2rc. If i specified a *.XPM image file and restart the fvwm i can see the image file set as a wallpaper. If i select a *.JPG, *.JPEG or *.PNG file i couldnt see any pictures/wallpaper coming up after restart the fvwm. My config file is as below:
If you have WindowMaker installed, wmsetbg can be used.
It will be scaled automatically.
Just when I run it using xcompmgr, i have to try several times until it works, but this might be as I don´t have the newest versions installed, same happens with xpmroot.
