I’ve just started to use fvwm, and I love it. At the moment i’m using it on Debian Sarge. The set-up I have looks pretty good, but i’d like to tweak it. Unfortunately, I am completely confused by the config files, even though I have read the man pages etc, many times. Do I need lots of files in addition to my .fvwm2rc, for example, functions, bindings, .start* ?
I am going to persevere with fvwm, as I love it, but to start with, I think i’ll be using the forums, a lot.
Thanks in advance for your thoughts.
Cheers,
Chris.
In short: No. You do not need any small files to separate out the various aspects of your configuration. Admittedly, some people do, but I lump it all in ~/.fvwm2c – there is nothing “better” about the segregate approach, its just a matter of preference.
HTH,
Thomas,
I deleted everything apart from .fvwmrc2, and restarted. Unfortunately, I now just have a basic blankscreen, without any of the different bits that used to be around the corners of the window…oops.
Is it better to try to run a set-up script, or can I “borrow” somebody’s nice config file from somewhere?
Thanks,
Chris.
Aaaah, I see what you’re saying now – you had an existing configfile which used separate files, and you werent sure whether you needed to keep them.
I mis-read your question in that I thought you were creating a new .fvwm2rc file and you wondered whether you had to separate out the functionality.
No loss, though – if you move your ~/.fvwm2rc out of the way (rename it), and restart fvwm2 – that should give you a default menu which will enable you to recreate the config file(s) that you deleted.
As for other people’s config file – depends what you’re after. If you see the fvwm screenshots page, that has a number of .fvwm2rc files to accompany them, should anything take your fancy.
HTH,
Thomas,
Thanks for that. Will see what other people have done, first.
Cheers,
Chris.
The best way to get into Fvwm, IMHO is to start with a basic setup and start tweaking and reading the man page. I started out by playing around with Eric Raymond’s setup http://www.catb.org/~esr/fvwm2. It is well commented, though a bit long in the tooth these days, but it will get you going in the right direction. Nothing fancy, but very well thought out.
Cga,
Looks like a good started. Thanks for the link.
Chris.
