Fvwm3 freeze for focus ... strange
… Hi …
I use Fvwm for a so long time … And i love it !!
Since Kernel 2,6 i have strange freeze … Before, 2.5.XXX it was OK.
I use fvwm3 but it happen too with fvwm 2,6
After a time … i loose focus … the only focus work is the back forward … the other (click left) doesn’t work.
I loose focus. No react. Fvwm3 freeze …
Strange … It work for 5 minutes … and after no. I have to kill X to go back to console and restart X and fvwm3 …
I use Nvidia Card. Before, 470 driver was used ( 2 nvidia cards in sli mode used). Now 550 driver with new alone card is used. The same result !!!
Thomas … HELP !!
Best regard,
Laurent (Aelsi)
Hi @laurent
I very much doubt this is going to be an isse with fvwm.
But the next time it happens, if you could switch to a VT, and get a snippet of what fvwm3 is doing using strace, that would be helpful.
Thomas, can you give me an email to send you the strace file ?
Hi @laurent,
thomas@fvwm.org
