As you can see, my sub-panels pop up under other windows, which is annoying.
I’m not sure how to go about setting style commands that will apply to those panels and not the main panel. It’s been a while since I’ve worked in the config file and it’s looking like greek to me again.
Well, a style string will apply to any window whose title or resource string matches the pattern given. So Style “" gets everything, Style "Fvwm” gets all the Fvwm modules and Style FvwmButtons gets all the FvwmButtons instances and, in this case, applies StaysOnBottom to them
Where there are multiple styles that match the one last defined in the config takes precedence. So you could, for example say
Style "Graphics" StaysOnTop
Style "Net" StaysOnTop
and so forth. The trouble there is that “net” and “graphics” are likely to catch other windows sooner or later. Better practice is to prefix your names with “FvwmButtons-”. Then you can say
Style "FvwmButtons-Graphics" StaysOnTop
Style "FvwmButtons-Net" StaysOnTop
with confidence that only your panels will be affected.
