[FVWM][style_parse_and_set_window_style]: <> Bad style option: TitleStyle Centered
I’ve tried to look in the man pages but i’ve just foud information redefining a new style. It works but the style is all changed, no only
the center position of the title.
The only way you can cahnge the TitleStyle for one window is by using the deprecated decor functions; and since there is no CopyDecor function you will have to create two identical decors with the only difference in the value of TitleStyle. So in your config file: Build up a new decor and give it a good name say “TitleCentered”. It should look just like your default decor, but have the line
