fvwm3 is migrating towards using meson as its build system. from the latest git checkout (hash: 1067a72e) i don’t see ‘FvwmConsole’ module being built.
FvwmPrompt has replaced FvwmConsole. The logic is if you have golang installed, FvwmPrompt will be built instead of FvwmConsole. If you don’t have golang installed, FvwmConsole is built instead. You can explicitly disable golang with -Dgolang=disabled in your setup.
I would suggest just moving to and learning FvwmPrompt. The only real difference is you don’t launch it from fvwm, instead just open up any terminal and run FvwmPrompt as a binary, and it gives you a shell you can send fvwm commands. You can also just use FvwmPrompt <fvwmcommand> if you want to send a single command with out opening up the shell.
Note you will need to load FvwmMFL using Module FvwmMFL from your StartFunction, since that is what FvwmPrompt uses to communicate with fvwm.
Note, just to clarify the above, in autotools, golang was disabled by default and has to be explicitly enabled, in meson, golang is automatically detected and builds FvwmPrompt if it is detected, so has to be explicitly disabled in that case.
yes that is exactly right ! thank you ! fwiw, after sending that message yesterday, i looked around a bit, and stumbled across the modules dictionary in the build file, and then the golang <---> FvwmConsole dependency right after that.
so that mystery got fixed.
however, i had no idea about FvwmPrompt, so thank you once again for clearing that up too ! as you have suggested, i have updated my configuration to load FvwmMFL during startup (specifically, during Init) and start a FvwmPrompt instance (within urxvt) as and when requested.
regarding your comment
once again you are right. i typically don’t build fvwm with golang support, and your explanation clears this up too !
