Hi all!
I have a problem with the option “MaxButtonWidth” in the FvwmIconMan module.
Well, in my configuration file i’ve put the line:
*FvwmIconMan: MaxButtonWidth 161
but launching Fvwm, i can see this error:
FvwmIconMan: bad line: *FvwmIconManMaxButtonWidth 161
FvwmIconMan: unknown option: *FvwmIconManMaxButtonWidth
Same with MaxButtonWidthByColumns …
I posted this problem even in Irc, but seems that this is a problem related to just my Fvwm…
The strange thing is that this option is documented in the web page, but i can’t find any line about MaxButtonWidth in my “man FvwmIconMan” …
Well, i can’t see any entry in manpage (and this is the really strange thing…)
However, my manager geometry is defined… can’t really understand…
However, thanx for help
Edit:
The options listed in “man FvwmIconMan”:
Name Description Default
NumManagers number of managers 1
Action binds command to event Mouse 0 N sendcommand Iconify
Background default background gray
ButtonGeometry size of button in pixels
Colorset default colorset
DontShow list of windows to ignore
DrawIcons use mini icons false
FocusAndSelectButton flat grey black
FocusAndSelectColorset
FocusButton style for focused buttons up grey black
FocusColorset
FollowFocus show which win has focus false
Font 8x13
Foreground default text color white
Format describes button label "%c: %i"
IconName manger icon name FvwmIconMan
IconButton style for icon buttons up black grey
IconColorset
ManagerGeometry size of manager in buttons 0x1
NoIconAction animate iconification NOP
PlainButton style for normal buttons up black grey
PlainColorset
ReliefThickness size of button relief 2
Resolution global/desk/page/screen page
Reverse normal, icon or none none
SelectButton style for selected buttons flat black grey
SelectColorset
Shape use shape extension false
Show list of windows to show
ShowOnlyIcons only icons visible false
ShowNoIcons icons are not displayer false
ShowTransient transient windows visible false
Sort keep managers sorted name
SortWeight weight for sorting
Title manager title FvwmIconMan
TitleButton style for title button raisededge black grey
TitleColorset
UseWinList honor WinListSkip? true
There’s no “MaxButtonWidth” or “MaxButtonWidthByColumns” …
I think the problem is that the features “MaxButtonsWidth” and “MaxButtonsWidthByColumns” have been introduced in the CVS version of Fvwm and not in the last unstable (2.5.12), as described in the official documentation. (same for the “tips” options)
Edit: my fault, because i saw just “2.5.x (unstable) documentation” and in the FvwmIconMan manpage there is the “(not released yet) 2.5.13” specification, which is referring to CVS version.
Now, the last thing is: why put the documentation for an unstable version if this is not released yet?
I’ve already asked to him, and all began due to his words. He told me that he can’t understand since he’s using 2.5.12 and has those options in man page… but this isn’t really true. Probably he’s using the Cvs version.
However, thanks for help and thanks to all the Fvwm community for the great work (special thanks to Taviso, for the patience ).
P.S. …do you know when probably will be released fvwm-2.5.13 ? (seems that this will be the next release, or at least that containing the “critical” FvwmIconMan options)
