Often I have to use a PC with 1 monitor and another one with two monitors.
I like to have the pager just in top-right corner of the only monitor in the first case or in the top-right corner if the right monitor in the second configuration.
Unfortunately I am not able to tune my config to have this behavior in both cases.
I assumed that using
FvwmPagerGeometry 91x50-00+00
should put the pager in the right position in both case but when using two monitors it puts the pager in the top-right corner of the LEFT monitor…
Since my home and therefor my config are shared using NFS I can not use two different configs…
Help is appreciated!
Thanks,
Massimo
