I’m using a simple TimeScript (I forget where I found it, I apologize to the creator ) that I’ve swallowed in a dock and will display the time. But I’m unable to display multiple lines - I would like to have the time displayed on one line and the date displayed on the next.
I’ve modified the TimeScript to look like this:
[code]WindowTitle {TimeScript}
WindowSize 100 22
Colorset 30
Init
Begin
Set $time = (GetOutput {date “+%l:%M %p%n%b %d”} 1 -1)
ChangeTitle 1 $time
End
PeriodicTasks
Begin
If (RemainderOfDiv (GetTime) 60)==0 Then
Begin
ChangeTitle 1 $time
End
End
Widget 1
Property
Type ItemDraw
Size 100 21
Position 0 0
Font “Shadow=0 se:xft:Verdana:size=8”
Flags NoFocus NoReliefString
Main
Case message of
End[/code]
The “%n” in the date function outputs a line break. If I run this command (date “+%l:%M %p%n%b %d”) in a terminal, I get the correct output:
6:58 PM
May 03
But I can’t get the second line to show up by using FvwmScript as such
*FvwmDock: (5x2+19+1, Swallow "TimeScript" "FvwmScript TimeScript")
All I ever get is the first line showing the time. Am I missing something obvious? Thanks in advance for any help!
