Hey all,
I have gaim 1.4.0-r2, guifications 2.10, and fv 2.5.12.
I’m having a problem with Fv switching to the desktop/page that the im window resides whenever a notification posts. Any ideas on how to fix this?
Thanks~
Hey all,
Thanks~
I want to know how to make the guification ignore the working area, I tried:
Style gaim* StartsOnPage 2 2, EWMHIgnoreStrutHints, \
EWMHPlacementIgnoreWorkingArea, \
EWMHMaximizeIgnoreWorkingArea, \
EWMHPlacementUseDynamicWorkingArea
but nothing happens with the notification area, I have:
EwmhBaseStruts 0 200 17 65
I got from xwininfo :
[code]xwininfo: Window id: 0x1e028d1 “gaim”
Root window id: 0xa0 (the root window) (has no name)
Parent window id: 0xa0 (the root window) (has no name)
2 children:
0x1e028d4 (has no name): () 191x44+0+0 +1209+17
0x1e028d2 (has no name): () 1x1±1±1 +1208+16
Absolute upper-left X: 1209
Absolute upper-left Y: 17
Relative upper-left X: 1209
Relative upper-left Y: 17
Width: 191
Height: 44
Depth: 24
Visual Class: TrueColor
Border width: 0
Class: InputOutput
Colormap: 0x20 (installed) Map State: IsViewable
Override Redirect State: yes
Corners: +1209+17 -200+17 -200-1139 +1209-1139
-geometry 191x44+1209+17
Bit gravity: NorthWestGravity
Window gravity: NorthWestGravity
Backing-store hint: NotUseful
Backing-planes to be preserved: 0xffffffff
Backing pixel: 0
Save-unders: Yes
Someone wants these events:
KeyPress
KeyRelease
EnterWindow
LeaveWindow
Exposure
StructureNotify
FocusChange
PropertyChange
Do not propagate these events:
Override redirection?: Yes
Window manager hints:
Client accepts input or input focus: Yes Program supplied minimum size: 191 by 44
Program supplied window gravity: NorthWestGravity
No zoom window size hints defined
Window shape extents: 191x44+0+0
No border shape defined
Initial state is Normal State
Normal window size hints:
Program supplied location: 0, 0
Bit Gravity State: NorthWestGravity
Window Gravity State: NorthWestGravity
Backing Store State: NotUseful
Save Under State: yes[/code]
Style gaim* StartsOnPage 2 2, SkipMapping
Should do the trick I suppose
so in talking to theBlackDragon in irc…we got down to the bottom of the issue.
Turns out I had the ‘Message Notification’ plugin enabled. God knows what I thought that was or what it did…but it was the culprit.
The dragon’s suggestion for SkipMapping and startsOnDesk/Page will also come in handy with gaim…but that’s a different issue.
I don’t know if that helped you Danes…
