Are there any general syntax guidelines when writing your own config?
I’m writing mine from scratch (and enjoying every minute of it), and while I think fv is the epitomy of freedom of choice in linux and computers in general…I don’t like having messy code. I take the extra time in making my code extra readable (at least to me), though I wasn’t sure if there were other things I should take into account here.
For example… I am looking at several different articles:
# Program Launching Functions
DestroyFunc AppXTerm
AddToFunc AppXTerm
+ I Exec exec xterm
This guy seems to put “fvwm” before all of his variables and functions…is this something I should consider? Personally I would:
DestroyFunc FvwmXTerm
AddToFunc FvwmXTerm
+ I Exec exec xterm
In Fvwm version 1, there used to be. That is, you had to have the functions listed in a certain order, and such. But that’s history. Nowadays there aren’t any syntax guidelines whatsoever.
All commands in FVWM are case-insensitive, although most like to use CamelCAse to show FVWM commands, which is fine. Personally, I tend (by way of using Vim’s folding techniques) to structure my .fvwm2rc file thus:
General hints such as ImagePath, EWMH* stuff, etc.
Style lines
Decors
Functions
Menus
Module commands
But it is completely up to you – whichever works best.
None whatsoever – the freedom is yours as to how you structure it.
As I said before, you can structure it to your heart’s content.
