I’ve been trying to get
echo -e '\007'
(or something like it) to work.
With the usual Gnome (version 2.28.0) and Metacity WM, the above
command produces the “alert” sound that is set in System–>Preferences–>Sound.
(This works for gnome-terminal, but not for xterm, not sure why it does not work—any thoughts?)
One also gets an alert sound for lots of other actions, like hitting the backspace key
when there is nowhere to backspace to etc.
But if I replace the Metacity WM with fvwm (using
fvwm --replace &
) I can’t seem to
produce any alert sounds at all. Nothing from
echo -e '\007'
or any of the other
sounds that are played when the Metacity WM is used, e.g., those that are in
/usr/share/sounds/gnome/default/alerts. My pc speaker works fine (e.g. it beeps
when I boot the machine), but I can’t seem to get either it or the gnome sounds to
speak to me. I can play the “alerts” files fine with /usr/bin/play, and in general the
sound system works fine, e.g., nice bluegrass from worldwide bluegrass through xmms.
Any thoughts for how to get alert sounds with fvwm, either the normal beep from
the pc speaker or by playing some sound file such as gnome does?
I’m running fvwm version 2.6.1, with my recently installed Scientific Linux 6.0 OS.
– Peter
