I’ve ended up with a gnome look/feel. This is 1024x768 on a slightly slow computer so I’ve removed stuff like FvwmEvent and Thumbnails. It is a
fairly simple config but depends on a few patches:
Various patches for decor etc (Needed for the decor):
http://abdn.ac.uk/~u15dm4/fvwm/
A quick patch to add rounded corners and padding to FvwmIconMan (Optional):
http://abdn.ac.uk/~u15dm4/iconman.patch
You can edit the define’s at the top but it’s fixed at compile time.
cd modules/FvwmIconMan
patch -p 0 < iconman.patch
StickyWindowStipples (Optional):
http://starshine.org/xteddy/thomas/fvwm/patches.html
For flicker free GotoPage/MoveToPage.
The config:
http://abdn.ac.uk/~u15dm4/fvwmconfig.tar.bz2
There are also screenshots of other configs here:
http://www.lynucs.org/?&frogb
