With older gnome-session versions, it was possible to use gnome-session for starting gnome and fvwm using the --choose-session option of gnome-sessions.
But with current gnome-session versions, that doesn’t work anymore. The --choose-session option is gone, and it is a --default-session-key. But I didn’t find any example of its use, and the only doc I found was in “man gnome-session”, and it doesn’t even tell if this option can be used for what I want to do, or if it is only for different gnome sessions.
I was able to run fvwm with gnome-session, by just running “gnome-session”. The obvious conclusion is than gnome-session will start fvwm if I want to start gnome.
In order to get back gnome, I must delete ~/.gconf and ~/.config/gnome-session/saved-session. After that, in order to run fvwm with gnome-session, I have to run gnome again and configure it to run fvwm and forget about gnome.
Is it some way to use current gnome-session to start both fvwm or gnome?
