In my config (fvwm-crystal), I have:
Mouse 4 R N GotoPage-Right
Mouse 5 R N GotoPage-Left
When the cursor is on the border of the screen, I can go trough all the pages in a circular way with the wheel.
If I have a focused window or previously focused window on page 1, 2, 3, 6, 7 and 8, and no window on page 4 and 5, when I start from page 1, the windows on page 2 and 3 will have the focus, but the focus will be lost from page 6, and it will never come back until I click on some window.
If I do the same with Ctrl-Alt-F, fvwm don’t loose the focus. Is it a way I can do the same (not loose the focus) with GotoPage? Or, can it be something wrong in my config, and if yes, what can it be?
I find a way to do that by modifying the function on Switch Focus to window on next page
[code]DestroyModuleConfig FE:*
*FE: new_page FocusOnGotoPage
*FE: new_desk FocusOnGotoPage
AddToFunc StartFunction I Module FvwmEvent FE
DestroyFunc FocusOnGotoPage
AddToFunc FocusOnGotoPage
- I None (CirculateHit, CurrentPage, Focused) Any (AcceptsFocus) Focus[/code]
I replace Next by Any, because Next was setting the focus on the wrong window when it is several window on a page.
I am surprised that fvwm doesn’t do that by default with a click to focus policy.
In fact, this is even more mysterious. Alt-F are not xorg bindings, but fvwm-crystal bindings defined as:
Key F1 A M GotoPage 0 0
Key F2 A M GotoPage 1 0
Key F3 A M GotoPage 2 0
Key F4 A M GotoPage 3 0
Key F5 A M GotoPage 4 0
Key F6 A M GotoPage 5 0
Key F7 A M GotoPage 6 0
Key F8 A M GotoPage 7 0
Key F9 A M GotoPage 8 0
Key F10 A M GotoPage 9 0
Key F11 A M GotoPage 10 0
Key F12 A M GotoPage 11 0
That imply than “GotoPage x y” is handling the focus in a correct manner, but “GotoPage-Right” and “GotoPage-Left” are not.
