Hello,
here my config very clearly inspired of the config of:
Desintegr
Taviso
Ikaro
Great thanks !!!
[color=darkblue]Gallery [/color]
[color=darkblue]Guli-Simply-v1.5.tar.gz [/color]
I’m, sorry, I speak French and litlle [size=75]litlle [/size] [size=59]litlle[/size] english
That definitely is a cool config, the colors match perfectly and are easy on the eye and the system monitor on the top right is way cool. I presume it’s an FvwmButtons module? I searched for it in your config pages but couldn’t seem to find it…
On this screenshot it is gdesklets : clan-hash.com/~guli/fvwm/Desklet/
but, on another screenshot you can see FvwmButton
clan-hash.com/~guli/screensh … 050102.jpg
pem
30 January 2005 20:34
4
You should have posted your latest conf with the rounded corner. It’s one of the most appealing conf I’ve ever seen! (note that this one is awesome too).
The ‘Gentoobox Tools’ menu item (sysup in your configs) in v1.5 of the config has limited functionnality compared to the one we can see in your screenshot.
Is it possible for you to post the most recent version?
Thanks in advance.
al1
3 February 2005 17:15
6
Yeah this one is seriously nice: clan-hash.com/~guli/fvwm/Scr … 050129.jpg
EDIT: just downloaded your config but i don’t see your Rox icons.
Any chance you can put them on you site or point me to where you got them from?
Thanks
Thanks, for the rounded corner, you can see the screenshot
clan-hash.com/~guli/screensh … 050129.jpg
It’s is shape with FvwmButton, thank you with the forums gentoo for its assistance
forums.gentoo.org/viewtopic.php? … 62#2061462
Here an example of config to make this shape
####Path des images pour les shape
SetEnv fvwm_shape_path $[HOME]/theme-fvwm/shape/
AddToFunc StartFunction
I Module FvwmButtons ShapeGaim
I Module FvwmButtons ShapeXchat
Shape
Colorset 150 fg #515457 , fgsh #c2c4c7 , bg #f6f6f6 , hi #ffffff , sh #718794 , Shape $[fvwm_shape_path]shape-gaim.png
Colorset 151 fg #515457 , fgsh #c2c4c7 , bg #f6f6f6 , hi #ffffff , sh #718794 , Shape $[fvwm_shape_path]shape-xchat.png
*ShapeGaim: Geometry 239x468-50+750
*ShapeGaim: Colorset 150
*ShapeGaim: Rows 30
*ShapeGaim: Columns 1
*ShapeGaim: Frame 0
*ShapeGaim: Font “xft:Verdona:bold:pixelsize=10:minspace=True”
*ShapeGaim: (1x1, Frame 0, Title(Center) “Liste de contacts”)
*ShapeGaim: (1x29, Frame 0, Swallow “Liste de contacts” Exec gaim
*ShapeXchat: Geometry 875x539+455+400
*ShapeXchat: Colorset 151
*ShapeXchat: Rows 30
*ShapeXchat: Columns 1
*ShapeXchat: Frame 0
*ShapeXchat: Font “xft:Verdona:bold:pixelsize=10:minspace=True”
*ShapeXchat: (1x1, Frame 0, Title(Center) “Xchat-2 IRC”)
*ShapeXchat: (1x29, Frame 0, Swallow “Xchat-2” Exec xchat-2
Style ShapeGaim NoTitle, Sticky, CirculateSkipIcon, CirculateSkip
Style ShapeGaim StaysOnTop, NoHandles, BorderWidth 0, SkipMapping
Style ShapeXchat NoTitle, Sticky, CirculateSkipIcon, CirculateSkip
Style ShapeXchat StaysOnTop, NoHandles, BorderWidth 0, SkipMapping
Download .png for shaping and cp in shape path
clan-hash.com/~guli/fvwm/Gul … e-gaim.png
clan-hash.com/~guli/fvwm/Gul … -pager.png
rupert-k :
Thanks in advance.
Yes, I will update my theme in little time;)
al :
Thanks
You can downlaod icons on :
interfacelift.com/icons-mac/
themexp.org/listings.php?type=icon&view=date
hy gulivert how i put your dock whit icons in my fvwm config?
And here
stylesuites.com/modules.php? … n=cat&id=6
all the icons are in :
~/theme-fvwm/icons
You can add or replace the new icons and edit gulidock. Change the path or name of icons
*OSXDock: (24x26+1520+0, Padding 1 0, Icon $[fvwm_icon_path]/find.png , ActionOnPress, Action(Mouse 1) DockLaunch "gnome-search-tool" $left $top
Hello,
My theme is made for one alone resolution, you can adapt the dock in your resolution, if you have a problem, you can send me a email
But in French language
Cya and good luck
hy, how you give to gaim that transparent thumbnail? i have already search on your configs, but i don’t see were is it, if you can tell me…
thanks!
fodasse tas em todas !! Meu man Fvwm , vais ficar impressionado , axo ke isso de andar a perguntar tudo a todos ja xateia um bokado !!!
hey guli~
I just started buliding my config from scratch; I really like your window decorations, especially the buttons/title bar, though I can’t figure out what to look at in your configs.
Can you give me some direction here?
Thanks~
Paapaa
15 September 2005 09:22
14
Nice theme!
How did you make those nice shadows around windows??
He uses xcompmgr for that, it’s the new xorg extension you’ve no doubt already heard about. Be awar though that it might disable OpenGL or do very weird things when OpenGL is enabled while using it (hardlocks X for me…)
Paapaa
15 September 2005 09:30
16
Ok, thanks! I’ll check it out. I so totally n00b to Linux world so I have no idea if I have OpenGL enabled or not…
Running glxgears or glxinfo will tell you that, if the former doesn’t run, then you don’t have OpenGL enabled
