Hide applications in pager
i have conky running in the background. Unfortunately it also apears on the pager, but it should not.
Is there a way to forbid certain applications to show up in the pager?
Thank you!
Yes. Tell the pager to use the skip list:
*FvwmPager: UseSkiplist
And for those applications you wish to have ignored, add a style option of WindowListSkip as in:
Style foo WindowListSkip
That really works great!
Thank you a lot.
chaosbringer
